crazy idea
Old Apr 14, 2003 | 10:48 PM
FordPerf300's Avatar
FordPerf300
crazy idea
I'm trying to make a simple dyno and am stumped on the equations to get HP, or watts if it is easier, by the data i can get. I'm going to have a laptop hooked up to the tach lead of my engine to pick up the pulses and turn that into rpm. That using the weight of the vehicle, final gear ratio, tire size and acceleration.
Am I crazy (sure i am) but, can anyone give me some help?
Old Apr 15, 2003 | 11:14 AM
rabidranger's Avatar
rabidranger
crazy idea
Wouldn't this be easier?
http://www.gtechpro.com/products.html
Old Apr 15, 2003 | 12:37 PM
pbrstreetg's Avatar
pbrstreetg
crazy idea
Hi-
Dyno's don't measure HP they measure torque. Then horsepower is calculated as a function of torque at a given RPM.
Like this:
torque x RPM
_________________ = HP
5252 (constant)
Which leads me to an old question. 2 engines are being tested. Engine1 turns 1000 rpm's and produces 1000 ft/lbs. of torque. Engine2 is turning 10,000 rpm's and is making 100 ft/lbs. of torque. Which engine produces more horsepower?
They're making exactly the same HP
Old Apr 15, 2003 | 02:01 PM
FordPerf300
crazy idea
I know how to get horsepower from torque, I'm doing this for a computer technology class. And i need to get torque bfore i can even het the hp.
Say the vehicle weighs 4000lb.
The transmission has a gear ratio of 3:1
The rear end ratio is 3:1
The tires are 32" tall (not factoring in tire deflection)
Hooking up a lead from the tach to the serial port of a laptop i can pick up the pulses of the coil, devide by the # of cyls and get a rudimentary tach.
Say i do a test run, from 1000rpm in second gear (3:1) to 4000rpm. From 0 seconds a program starts a log.
time - rpm - after gearing
0 sec - 1000rpm - 111.11rpm
.5 sec - 1100rpm - 122.22rpm
1 sec - 1200rpm - 133.33rpm
1.5 sec - 1300rpm - 144.44rpm
etc......to 4000rpm - 444.44rpm
for ever .5 second the engine is increasing 100rpm
and for every .5 sec the tires gain 11.11rpm
i'm stuck on how to put everything togeather.
Old Apr 15, 2003 | 02:04 PM
Jens's Avatar
Jens
crazy idea
[QUOTE]Originally posted by pbrstreetg
[B]Hi-
Like this:
torque x RPM
5252 (constant)
pbrstreetg, if it so than a 6.9 ltr Diesel must have approx. 226 hp.
330 x 3600
___________ = hp
5252
Could it be????
Jens
Tmccauley
New Member Introductions
Jan 20, 2017 01:08 PM
f100guy
Jan 4, 2004 12:29 AM
emtabmm
Dec 19, 2003 09:04 AM
Greywolf
13
Dec 4, 2001 10:32 AM
