Sponsored by: Real Truck
WARRANTY PROBLEMS ?
Old Dec 4, 2011 | 04:40 PM
Baddogzz's Avatar
Baddogzz
WARRANTY PROBLEMS ?
Hi,
I have A new 2012 F-250 SD 6.7 and want to put A lift kit on. I drive in fields with tall CRP grass and would like to decrease the possibility of catching the grass on fire and not high centering on the terrain I go through, It's basically farm land.
The service mgr. in my area here in Texas says my warranty will be void if I put A lift kit on it.
Does anybody have any info on this whether or not FORD will void the warranty ?
Thanks
Old Dec 4, 2011 | 05:13 PM
galaxie641's Avatar
galaxie641
Anything they can pin on the lift causing the break will not be covered.
Old Dec 4, 2011 | 06:05 PM
rollerstud98's Avatar
rollerstud98
They can't void your motor because of the lift is what people say.
Old Dec 4, 2011 | 07:05 PM
dkf's Avatar
dkf
Hes full of it.
Old Dec 4, 2011 | 08:00 PM
Fordfanatic4life's Avatar
Fordfanatic4life
find another dealer..
Old Dec 4, 2011 | 08:30 PM
Baddogzz's Avatar
Baddogzz
The service mgr claims that if I put larger tires, usually associated with the lift kits, That it will put more strain on the motor and trans therefor the void of warranty..
Is there any way to get an answer to this from FORD itself ?
Old Dec 4, 2011 | 09:36 PM
dkf's Avatar
dkf
Tell him to show you where in Fords policy it states that.
If that has any merit then pulling a trailer or hauling anything in the truck would void the warrenty also. If the larger tires, lift and etc are directly related to a premature part failure don't expect the warrenty to cover it.(ball joints, brakes, wheel bearings and etc)
Old Dec 4, 2011 | 10:03 PM
Baddogzz's Avatar
Baddogzz
I agree dfk, I think he's full of *#&@ !
Gonna go chat with the mechanics tomorrow and pick their heads a bit, from what I understand their the ones that make the call whether or not to report to Ford anyway on warranty stuff.
Old Dec 4, 2011 | 10:22 PM
XB70's Avatar
XB70
Who says Ford will pay when you haul max weight with a lift kit and tall tires?
In addition to increasing unsprung weight, putting additional stress on steering components and a variety of other components, larger tires increase (numerically decrease) the rear end ratio.
Load the truck, drive it up the Grapevine or your grade of choice and something will give. On 6.0s, it's the head bolts. Big tires do, in fact, contribute to engine and transmission failures.
Back in 2004 a friend of mine who owns a large Ford dealership in southern California showed me a letter he received from Ford. He had been accessorizing new trucks with bigger tire/wheels and Ford flatly stated that such installations could void the warranties. He stopped immediately.
Ford nor any other manufacturer will not flatly state anything will void the warranty. That determination is made post mortum, after a wrecker hauls your broken-*** modded - lifted truck into the service department.
Old Dec 4, 2011 | 10:37 PM
XB70's Avatar
XB70
Not really. Ford requires dealers to send back virtually all warrantied parts for analysis. The even got the foam from my 2004 Mach 1's driver's seat from the dealer after a warranty replacement.
The mechanics don't make the call. Additionally, FoMoCo will charge back any warranty repairs to the dealer if they find fraud. That's what you're talking about. Finding a mechanic that will help you defraud Ford if your modifications break your truck.
Old Dec 4, 2011 | 11:16 PM
rollerstud98
Actually, the techs do make the call, they recommend whether it should be a warranty repair or not.
Old Dec 4, 2011 | 11:42 PM
XB70's Avatar
XB70
Sure they do. So, what is the function of the Service Director, Service Manager and Service Writer?
By the way, recommending isn't deciding.
Old Dec 4, 2011 | 11:53 PM
rollerstud98
Tech still makes first call. Sure those other guys can go over his head, but he still makes the first call, if he brings something suspicious up, even if nothing suspicious is there, **** can hit the fan for you.
NickBurk
Dec 15, 2008 07:04 PM
marv02
Feb 26, 2006 08:20 AM
carissathompson
1997 - 2003 F150
Apr 11, 2004 03:15 PM
lowharley
Jul 19, 2003 06:23 PM
clown926
1997 - 2003 F150
Jul 9, 2003 06:31 AM
