88 f250 351w wont run
fuel pressure at the fuel rail is 40psi, clogged fuel filter made it read lower. i do still have spark with spout in or out, at coil and at plugs. still it will not start. i am coing to charge the battery and hit it with some starting fluid after work and see if it tries to start. if not, any thing else that i can eliminate?
tried to hit it with starting fluid and didnt even try to start. one time it blew a flame out the throttle body but that was once in 5 min of trying. fuel pressure said 40 psi the whole time. My dad let me borrow a NIOD light set to test fuel injectors and they are cycling. well--now where to start??
A fuel rich condition may have caused oil to be washed off the cyl walls. Try cranking and holding the throttle at wide open, that should shut down the fuel injectors and hopefully give you a close enough mixture to attempt to start. As a secondary check, near the battery negative terminal there's a plastic plug that sometimes has the pins dissolve, this is a dedicated ecm ground and can cause all sorts of weird issues.
It does sound like it could have washed the walls with gas and lost compression but when you're cranking, does the cranking speed sound even or does it sound like something is irregular as its turning over. A second check is to put a compression gauge in the plug hole or at worst put your finger near the plug hole with the spark plug removed, see if you get the big spike of pressure at the same relative moment as the spark happens. Its possible that it has jumped time, not likely but possible. If you have a timing light you should be able to get a reading off the crank while wheeling it over. Cleaning your plugs off with a propane torch might help you out. It sounds like you have fuel, and some spark, but the events are not in the right sequence. Checking with a timing light will be a big help. Another thing, driving and lost power, its possible maybe that you melted a cat and your exhaust is so plugged your engine won't run.
no cats on my truck. longtube headers and mmagnaflow mufflers only. i am going to put my battery on charge cause it does spin a little slower than normal. as for the compression, my dad put his thumb on the hole and i cranked the motor and it blew his finger off the hole. i also did trip the fuel shut off on purpose so it wouldnt flood my engine. and yes i did reset it.
#29
