Random Thoughts
Old Dec 3, 2011 | 03:54 AM
droy22010's Avatar
droy22010
Unhappy Random Thoughts
I have had my 06 f-350 for about 4 days now i bought it from a dealership running it normally not beating on it or driving it rough and today as i was taking my wife to the movies she points out that my check engine light is on i haven't gotten it checked yet but is this a bad omen and get the dealership to give me another truck or should i try to go through the hassle of extended warranty....this is my first diesel and i was hoping and praying that it would be a pleasant experience.
Old Dec 3, 2011 | 06:30 AM
Rusty Axlerod's Avatar
Rusty Axlerod
I would definitely get them to scan the codes and see what's up. Hard to say what to do until you know what the problem is. Could be somthing small and inexpensive. Many guys have the extended warranty(I do not). it's not a bad idea if it's through Ford. There are several types/levels of coverage. If they only offer you a third party plan, I would skip it and take my chances.
Old Dec 3, 2011 | 07:16 AM
EXbowtieguy's Avatar
EXbowtieguy
+1.... VERY solid advice !!!
If you do decide to keep it the FIRST thing most will tell you to do is get an OBD2 aftermarket guage set up, most use the Scanguage2 , I use the edge Insight CTS.
Ive come to the conclusion that you should have one before you buy your first tank of fuel..... They can stop ALOT of the chain reaction issues that diesels are prone to as long as you watch them.
Good luck !
Old Dec 3, 2011 | 07:34 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE droy.. As mentioned, have it checked.
Old Dec 3, 2011 | 01:48 PM
droy22010's Avatar
droy22010
Where do i find a new gauge cluster for my rig?
Old Dec 3, 2011 | 01:55 PM
BLADE35's Avatar
BLADE35
Do you mean a ScanGauge or what?????
you can get it from AutoZone or from the SG company
www.scangauge.com
heres a good thread to check out on the SG and all that it does
https://www.ford-trucks.com/forums/1...injectors.html
Old Dec 3, 2011 | 04:12 PM
High Binder's Avatar
High Binder
I'd just get another truck. I'm sure they're really nice guys and will have no problems just swapping you into another truck.
Old Dec 4, 2011 | 11:10 AM
droy22010's Avatar
droy22010
when i read the code it came out say cylinder 7 glow plug circuit now could this be the actual glowplug or something enirely different
Old Dec 4, 2011 | 03:18 PM
BLADE35's Avatar
BLADE35
It could be a bad Glow plug GP Harness or GPCM
at any rate its not the end of the world theres lots worse codes than that you could have got
I would suggest a scangauge to chech the truck out with theres a few things to watch for with these trucks
TruckGuy27
Feb 15, 2013 11:20 AM
Georgiaboy528
Mar 12, 2010 07:42 PM
michael62
Jan 23, 2010 09:38 PM
blown88
Mar 31, 2009 11:13 PM
