Rear Panel removal
Old Nov 30, 2011 | 11:32 PM
Elk4me's Avatar
Elk4me
Rear Panel removal
I have a 2002 Explorer Limited that I bought last week. The Keyless Entry code didn't come with it. I am wanting to remove the rear speaker and vent cover on the right side panel and need to know if it is a friction fit retainer type or attached from the inside necessitating removing the hole panel. I know I saw something on this but my last search didn't come up with the answer.
Thanks,
Scott
Old Dec 1, 2011 | 06:44 AM
shorod's Avatar
shorod
You shouldn't need to remove the entire inner trim piece. Instead, open the passenger side rear door and pull the weatherstripping away from the trim piece where the rear of the door meets the panel. Then you can pull the panel away from the body. The panel is held to the body with those push-in style clips. You should be able to pull the panel away from the body far enough to see the Central Security Module (CSM) using a good light and hopefully also see the 5-digit code on a sticker affixed to the CSM.
-Rod
Old Dec 1, 2011 | 11:28 AM
Elk4me's Avatar
Elk4me
Thanks Rod, I will give it a try. I was under the impression that the module was farther back.
Old Dec 2, 2011 | 06:57 AM
shorod's Avatar
shorod
On at least the 1996-2000 Explorers it is, and it's on the driver's side.
-Rod
Old Dec 2, 2011 | 09:39 AM
turborich's Avatar
turborich
I've read that it's further up on the 02+ Explorers. Behind the panel, next to the second row of seats. This is what info is available on a google search.
Old Dec 2, 2011 | 10:56 PM
shorod's Avatar
shorod
Correct, see post #2 above.
-Rod
Old Dec 4, 2011 | 11:39 PM
Elk4me's Avatar
Elk4me
Thumbs up Got it done
I got the code for the Keyless Entry Keypad by removing the Pillar cover and prying out the lower panel just as stated above. Thanks for the info.
Note: it is on the right (passenger) side just behind the back passenger door.
Old Dec 5, 2011 | 06:48 AM
shorod's Avatar
shorod
Cool, thank you for following up with your success!
-Rod
Blade70
Mar 30, 2011 04:33 AM
036.0
Sep 17, 2007 11:21 AM
kiosk
Aug 27, 2006 01:41 PM
jrahn
Sep 10, 2004 08:39 PM
rbrad9753
Paint & Bodywork
Feb 9, 2002 06:13 PM
