I have a couple pics of the back of a 91 460 showing the stainless lines, but don't know how to post them. I'll try to get my son to help tomorrow. They are 5/16ths I think, have quick clip attachments at both ends, about 12-15" long. I can get good pics of them soon as I get my 460 back from the machine shop in a few days if that will help.
Still don't have the 460 back, maybe tomorrow. The pics I have are not real good as far as the lines go, so will wait for good ones. Maybe your guy can help me find a harness for my 460. I need the one from the ECU at the drivers side firewall to the engine for a 91 F series 460 with manual trans. I have only looked once at the Upull & found one that had been cut. And if I go back soon I might find the lines you need. Soon, I hope, Charles.
I believe I have that harness. But it is actually two the way you describe it. The front end harness has the ECU and TFI module connections then has four round 8 pin connectors, white, brown, black and gray. The engine part goes from those to all the engine connections including the air conditioning compressor.
I think I must have the engine part of the harness, but not the section between the ECU and 4 connectors to the engine. I should have my 460 home tomorrow sometime so I can get pics of the fuel lines and also the harness.
Got the 460 home & got pics, tried to send a PM but apparently don't have enough posts? Try to PM me your email & I'll send pics of those lines.
If the harness is the same as a small block I should have no problem finding one in the Upull, except maybe digging in the snow. Thanks, Charles.
Charles, it won't let me PM you, probably for the same reason so I left a visitor message for you. The only harness that might not work would be a 6 cyl. Just be sure you get one with the remote TFI module.
Try this link to Supermotors & see if it works for you. It should show two pics of those lines. I may go to JY in a day or two & I will look for those lines, I need the ones that connect from them to the tank.
