2001 7.3 Leaking and Blowing Oil
On a recent trip home from a KS deer hunt I was pulling my 6000# travel trailer and noticed a loss of power when climbing hills. I noticed an unusual whiring sound from the turbo. When I stopped for fuel I could smell the burnt oil that was leaking and noticed a lot of oil residue on the front and right side of my travel trailer which is the exhaust side of the truck.
Checked the oil and I was over 3 quarts low. The truck continues to use oil and leak onto driveway some, not as bad as the 500 mile trip while towing but still noticeable oil use.
I have been told it may be the turbo seals? Any Suggestions would be appreciated.
This truck has 355K on it and has been a great vehicle overall.
Sounds like a blown turbo, they are rebuildable, hopefully your housing isn't thrashed.
Here is a sponsor with some parts available.
Riffraff Diesel Performance Parts: - Turbo Rebuild Kits
Here is a write-up on the rebuild http://www.guzzle7pt3.com/vanturbo.php
most of the time the pedestal just leaks on the motor to go out the exhaust it has to get past the turbo shaft in to the housing.
this is the rebuild for turbo and it comes with the pedestal orings
Replacement O-rings for Ford Diesel Engines
this is just the orings
here is the write up on the van turbo rebuild
Welcome to BDrummonds Van Turbo Rebuild Web Page
OK guys I parked my truck and quit driving it. Beautiful day so I thought I would get started. First thing on the instruction list is remove the compressor intake duct and crankcase breather after unplugging the green hose from it. I do that and where it was attached to the compressor there is about a 2" split in the hose right behind the clamp.
Could this be what is causing it to suck so much oil? If I replace this hose could my problem be solved. Or do I need to continue on with turbo removal and replace this portion of the hose as well.
Thanks in advance.
Mark
Thanks in advance.
Mark
