EGR or not??
Old 11-28-2011, 06:53 PM
acf6's Avatar
acf6
acf6 is offline
EGR or not??
Im considering buying headers for my truck.. im just wondering, do i have an EGR fitting or not? 03 5.4L. Thanks!!
Old 11-28-2011, 09:12 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
You should, the steel pipe with 2 small hoses attached to it , half way down,that goes from the throttle body egr valve to the drivers side exhaust manifold , the drivers side header will come with a threaded hole in it for the egr fitting that you are to remove from your old manifold, but most likely it will be rusted frozen, a new fitting is like $35 ,install into new header and attach egr tube, dont forget the anti-sieze for the fitting
Old 12-02-2011, 07:00 AM
phil6608's Avatar
phil6608
phil6608 is offline
03 F-150 5.4 dose have an EGR. Not to sure about the F-250s. Some of them do not have EGRs.
Old 12-03-2011, 08:09 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It should be easy enough to see at the rear of the manifold near the pipe flange.
Old 12-20-2011, 04:39 PM
acf6's Avatar
acf6
acf6 is offline
Thanks guys, just remembered about this thread so i went outside to look. it appears i am EGR equipped
landscapeguy
1999 to 2016 Super Duty
02-10-2019 12:47 AM
AAubinoe
07-31-2014 11:28 PM
L3ordum
Modular V10 (6.8l)
08-28-2012 06:58 PM
acf6
11-28-2011 08:14 PM
aphotic26
Modular V8 (4.6L, 5.4L)
15
01-27-2011 07:54 PM
Quick Reply: EGR or not??
