Offroad & 4x4
Rims
Old Nov 27, 2011 | 06:24 PM
77mud's Avatar
77mud
Rims
okay been looking a set of rims for my 97, found a nice looking set of rims on evilbay 16x8 rebel racing wheels they were the 5x135 but the compatibility thang said they would not fit the 97 f-150 4x4 xlt... am i wrong by thanking that they are 5 on 135?
also any suggestions on were to find decent looking 16" rims that wont break the bank?
Old Nov 28, 2011 | 12:34 AM
fatdan460's Avatar
fatdan460
they should be the metric 5 lug pattern from 97 all the way to when they changed body styles (04?) and went to the metric 6 lug sheot on the newest trucks.
Old Nov 28, 2011 | 02:07 AM
alpha/omega's Avatar
alpha/omega
Drill the holes out a few sizes and put some washers under the lug nuts.
Old Nov 28, 2011 | 05:37 AM
77mud's Avatar
77mud
The Guys in the 97-03 forum finally came around and answered and like i thought it is 5 on 135 just mine has 12mm studs and these new ****s got the lug nuts with the washer that hold the rim right instead of the old tappered style lug nut
Old Nov 28, 2011 | 03:24 PM
77mud's Avatar
77mud
what exactly is a -6mm offset?
Old Nov 28, 2011 | 07:12 PM
hav24wheel's Avatar
hav24wheel
Wheel mounting surface is 6 mm twards the back of the rim, measuring from the center of the width..
Old Nov 28, 2011 | 07:21 PM
77mud's Avatar
77mud
gotcha, so a 0 would be bassicaly midway of the rim?
Old Nov 28, 2011 | 07:23 PM
hav24wheel's Avatar
hav24wheel
Yes. 0 would be centered.
N at least I think - #s go twards the back of the wheel....
Old Nov 29, 2011 | 03:50 PM
77mud's Avatar
77mud
<fillll>
Old Nov 29, 2011 | 08:56 PM
alpha/omega
Correct...
a positive offset would make the rims stick out farther from the rims centerline. Negative would make the rim sit a little more under the truck.
6mm is roughly 1/4" which I dont think will matter one way or the other.
Old Nov 30, 2011 | 12:02 AM
fatdan460's Avatar
fatdan460
tell that to your wife :flipoff2:
ZING!!!!!
Old Nov 30, 2011 | 04:26 AM
77mud's Avatar
77mud
in other words a -25 would set a inch closer to the frame rails than a 0 offset would?
and then a 25 offset would set roughly a inch farther out the fender wheels than a 0 would?
if so....
this calculator is showing the exact opposite...
Wheel Offset Calculator
Old Nov 30, 2011 | 04:28 AM
77mud's Avatar
77mud
This one to...
Old Nov 30, 2011 | 05:57 AM
hav24wheel's Avatar
hav24wheel
Well, than, kris is backwards....
I explained it right, - offset moves the wheel mounting surface closer to the back of the rim(sticks out the fender more) and+ moves it to the front side to the rim (closer to the frame)
Old Nov 30, 2011 | 04:46 PM
77mud's Avatar
77mud
I understood you to say that, it threw me off when he said 'correct' and said it backwards... lol
