Help please
Old Nov 26, 2011 | 09:20 PM
89idihauler's Avatar
89idihauler
Help please
My buddy 95 will crank over but will not start. Is there any things that go out on these that can cause this to happen. Truck has around 200000 any help please
Old Nov 26, 2011 | 09:47 PM
mojoman's Avatar
mojoman
first check to see if the tach moves when cranking...CPS is a common problem that is a simple fix...no tach movement=new CPS....I believe the grey one is what most recommend....you could also check fues 22...it controls the fuel heater and PCM if I remember correctly...but those who know better will chime in I'm sure...hth
Old Nov 26, 2011 | 10:09 PM
89idihauler
What's the cps
Old Nov 26, 2011 | 10:27 PM
89idihauler
Bump to top
Old Nov 26, 2011 | 10:30 PM
oldbird1965's Avatar
oldbird1965
Crankshaft position sensor on the front of the motor at about 11 oclock position. Like said, it a common problem, easy fix for about $25.
Ford4Life7.3's Avatar
Ford4Life7.3
Cam position sensor. Check for tach movement like he said.
Old Nov 26, 2011 | 10:32 PM
bad12jr's Avatar
bad12jr
Cam position sensor. Go to ford and get one. If the Tach doesn't move its probaly your problem. Also as said above check fuse 22. If the fuel heater in the bowl breaks loose it will kill the pcm power. Don't why they put em on the same circuit but they did. Two easy things to check first. Let us know what happens
Old Nov 26, 2011 | 10:59 PM
89idihauler
He said he did change that any thing else?
Old Nov 26, 2011 | 11:00 PM
89idihauler
Cps that is
Old Nov 26, 2011 | 11:01 PM
89idihauler
I'll tell him about the fuse . Anything else? Thanks by the way
Old Nov 26, 2011 | 11:12 PM
Ford4Life7.3
Check if theres oil in the hpop, high pressure oil pump
Old Nov 26, 2011 | 11:17 PM
Ford4Life7.3
Also, i know your friend replaced the cps, but ask him if it was a motorcraft cps. If it werent, it couldve gone bad. I know that a few guys have had their non motorcrafts go bad in weeks.
Old Nov 26, 2011 | 11:29 PM
89idihauler
They just fixed it when it happend cps and the fuse I'll have him check. How do u check the oil in hpop
Old Nov 26, 2011 | 11:44 PM
oldbird1965
The reservoir is in the front of the motor with a hexagon bolt in it. Oil should be half inch or so from the top. A lot of cranking will lower the oil level.
Old Nov 26, 2011 | 11:52 PM
89idihauler
So is that about what would make this happen any more suggestions
