Transmission or something else?
Old Nov 26, 2011 | 07:18 PM
jrank's Avatar
jrank
I have a 2011 f150 4x4 sc 5.0 engine.Sometimes while driving at parking lot speed it seems the engine rpm stays up around 1000 while slowing to a stop and this causes a surge when you take back off.Anyone else noticed this?
Old Nov 27, 2011 | 03:13 AM
640 CI Aluminum FORD's Avatar
My 2011 FX4 5.0L does the same thing...I don't think anything is wrong with the truck. To my understanding that's pretty much just how these new 6-speed transmissions operate.
As long as its not clunking really hard into to gear, or grinding any, I wouldn't worry about it.
Old Nov 27, 2011 | 08:43 AM
jrank's Avatar
jrank
No noise or hard shifting.When you are trying to just idle around to find a parking spot sometimes the engine rpm stay up a little to much.Maybe it is normal I don't know.Thanks for the reply.
Old Nov 27, 2011 | 10:21 AM
Yeah what you described is normal I beleive.
Old Nov 27, 2011 | 12:36 PM
efx4's Avatar
efx4
At low speeds the trans can go to first gear if the speeds are low enough, thus causing higher rpm's and surging and rapid slowing down when letting off the gas. My 2010 does the same thing. First gear is so short (4.17:1), this would cause this if it doesn't shift to second gear at low speeds.
Old Nov 27, 2011 | 06:09 PM
jrank's Avatar
jrank
That makes sense efx4.Thanks
Old Dec 1, 2011 | 07:23 PM
goalyman09's Avatar
goalyman09
my 2011 5.0 does the exact same thing dont think its anything to worrie about
RJ sheedy
Dec 16, 2016 12:10 PM
landscapeguy
Nov 22, 2016 09:52 PM
raven3
5.0L Coyote
Feb 10, 2015 05:35 PM
Steve680
2009 - 2014 F150
22
May 13, 2014 09:32 PM
shendoa
16
Nov 20, 2004 08:47 AM
