1978 - 1996 Big Bronco
Cruise Control
Old Apr 14, 2003 | 02:52 AM
dassmoof's Avatar
dassmoof
Cruise Control
Sitting in my Bronco today on my break at work, pushing my non-working buttons for cruise control, I wondered what it would be like to have it. So I'm curious, how exactly do I get it working? It just doesn't work, hasn't since I bought it.
Old Apr 14, 2003 | 06:24 AM
Broncomule's Avatar
Broncomule
Cruise Control
You probably need to grab your 12 volt test light first and verify that you have current at the unit. If not find the blown fuse and replace it.
Old Apr 14, 2003 | 12:17 PM
yosemite's Avatar
yosemite
Cruise Control
There are several other things you have to look for. I only really know 2.
1) The sensor on the brake goes out. Might have to replace. Mine isn't sensitive enough so I may do that.
2) My problem..... the spring rod on the turn signal switch in the steering column that connects the cruise to the metal on the steering wheel(allowing you to turn the wheel and not mess up wires) was broken off of mine. This means that the controls on the steering wheel wasn't getting any power or able to send signals.
The spring rod for the horn was also breaking at the time... honking when i turned.. not when I pressed the horn pad. That's how I found my problem. Had to replace the turn signal switch and the horn and cruise works now. $60 part. Or maybe the wire is just broken not connected to the spring rod in the steering column. Mine was broken and the wire wasn't connected.
Brian
Old Apr 14, 2003 | 04:31 PM
Kemicalburns's Avatar
Kemicalburns
Cruise Control
you could also have a vacum line that is cracked or off.
good luck
Old Apr 16, 2003 | 01:11 AM
steve83's Avatar
steve83
Cruise Control
First, you have to tell us what year the truck is. If it's '92 or older, you have the vacuum system. If it's '93 or newer, it's all electric.
Larboy
General Diesel Discussion
Mar 2, 2017 01:17 AM
hotboxdp
1997 - 2003 F150
May 25, 2016 07:33 PM
Phillime
Mar 26, 2016 12:31 PM
Domino
Mar 27, 2015 03:15 PM
