69 F350 Bump Side Crew Cab Restoration
#31
I have a 94 dodge 1 ton 4x4 sitting out back and the front axle is not one that i would be happy with , they have a single unit wheel bearing that cant be replaced by it's self comes with the hub ! and no locking hubs ! I like things the old way !
but with coil springs they might almost line up with whats on there !
one thing , make sure that the CASTER gets set correctly when you put all the brackets on that you will need or it will give you a big dose of DEATH WOBBLE !
#32
#33
there is nothing wrong with the dodge front axle if you get it for a good price !
a dana 60 from a 78-79 ford would be good , hard to find and can be expensive !
a dana 44 from any high boy 75-77.5 would work , putting springs under your truck is not that bad of a job !
a new dana 60 from 87-96 +- a year or 2 will work the newwer ones have ball joints as the older ones have king pins !
#37
D350 Front Stub
So here is a pic of a 95 4x4 front stub. This is what i have located locally, thought is only an image i got online, to install on my F350 crew cab. I am wondering how difficult it will be to get the bracket that is just in front of the cab mount lined up for the stabilizer arms to work properly? I've been warned about a death wobble. I'm guessing that to be an out of control wobble of the front wheels at highway speeds. Feel free to educate me
I made some calls this morning to a couple of salvage yards. Most are still closed for Christmas break, but a guy in nashville tried to convince me that a newer superduty front end would be just as easy to put in my 69. I know i have to fab everything, so what will be the best 8 lug to go with.
#38
#39
Would then the ABS stuff give me trouble? It might just be easier to locate an older wrecked superduty. The wheels for those things are crazy high though!
#40
liking the project but what's making you go down the hard trail with your front axle and frame setup? if i were you why not build your own front solid mount leaf spring crossmember and run 99-04 or newer super duty leaf springs and drop in a 70's dana 44 or 60 with disc brakes. this is exactly what i did on my 71 f250 crew cab 4x4 it was pretty simple to do and is a great setup also will ride alot better then what these trucks stock suspension is. sounds alot easier then what your trying to do
#41
club cab
when i cut the frame on the half ton after the hangers i get the 44 high pinon and i get the three link then comes the softer ride with more travel. disk brake front . it is all ford 4 in lift coils in front i can 3/4 or 1ton spring it in the rear and haul anything via 60 series east change to the serling 10.25 if i want all disk and the 400m and 351m have same bellhousing so i get my 460 powered stump puller
#42
I want to stay 8 lug 6.5 centers on the wheels. I'm not married to the dodge front end, it is just all that i can find locally. I don't think i could afford to build the dana 44 to stand the torque of a 5.9 cummins. It would be great to find a 97 or older front differential that i could build the carriers for.
#43
A Dana 60 front axle from a 70's Ford will bolt right in no problems with factory leaf width and will handle the cummins no problem what kind of suspension are you wanting in the front and how high of a lift 4 link coil spring or leafs this may help determine what axle would be best to use also what transmission and what side front output t case drive will you have drivers or passenger side?
#44
go go club bump
i'm running a 50 in my excursion (7.3) and it is a 44 with a bigger set of axles 44's are tuff if gets and after market long axle, replace it and they are a hard nut to crack ..just make sure and keep and eye on the bushings on the dodge front end and you wont get a death wobble there is where the problem is. other than that it should make you a good runner need to bush them bout 90k or so most often and they are good to go.
#45
