71 360 timing chain help
i have a 71 360 i took out of my 71 f250 crew 4x4 i'm going to use to put in my other truck i took off the timing cover and seen the chain was alittle loose i took some pics to see is this to much slop in the chain or is it still good i don't want to skip teeth and get stranded do i have the plastic coating gears?
From the pics it doesn't look like you have a plastic cam gear and the slop doesn't look excessive. I always try to jump the chain with my fingers. If it even looks close, I replace. Cheap compared to jumping the chain and your already there labor wise.
From the part number plainly visible on the cam gear, I'd say it has already had the chain/gear replaced once (at least). Looks like a steel gear to me. Chain is a bit loose, but not bad. I'd say replace it, since you're already there.
Make sure you rotate your crankshaft until your timing marks line up, before making the change.
Search Results for ford fe timing sets - SummitRacing.com
Thanks for the link what's a good timing set to go with I see there's acouple choices anyone have a preference of which you like to use
Most of the shops that are rebuilding FE's have employees that were born after the last FE was produced. That is why you see some cam plugs installed backwards at some shops. Most FE builds are done as cheaply as possible. There are only a few specialty shops that build high performance FE engines. To say that most agree to use one brand of timing gear set is a stretch, unless they install the cheapest gear set that they can buy that will last past their warranty.
thanks for all the replies i went with a comp cams 2108 double roller i may need some help putting it on in acouple days when i get it. i should rotate the crank until the marks line up and then switch them that's it?
Remember to use Loctite on the cam retaining bolt. You don't want it to come loose. I also squirt some oil on the dry chain and gears after installation. To keep the pan gasket from leaking, you can cut away the exposed pan gasket and clean the surface, then use your favorite gasket maker like the below to seal the pan to the bottom of the timing cover.
After installation, it is always a good idea to replace oil and filter. You are on your way to becoming a FE guru.
Yes, line up your timing marks before removing old set, and of course line up your timing marks on your new set before you install them.
Permatex 29208 | Liquid Gasketing & Silicone Sealants
I'm replacing the front timing cover seal for the crank what's the best way to remove and install the new seal? I'm guessing there's a tool made for it but I don't own one what are some common things laying around that others have used instead to put the new one in?
