rum-rum-rum transfercase sound
Got a 1356 tc and at 55mph it vibrates badly and makes a rum rum rum sound.
I can feel and see it in the shift levers.
This spring I found that I was running it really low on grease for about a month which equates to about 500 miles give or take.
I couldn't take it out of service so I topped off the case.
It has increasingly got worse.
I replaced some worn u joints so I know the noise is not them.
The rear output shaft has a lot of play coming out of the rear of the tc.
Other than the noise it shifts fine.
Is there a bearing that can be replaced at the output end or is it going to be more involved than that?
Thanks for your help.
If you need more info please let me know.
