cab differences
Old Nov 24, 2011 | 11:56 AM
fila5716909spruce's Avatar
fila5716909spruce
cab differences
Hi,all . Newbee here, will a1966 f-800 cab fit as a replacement for 1962 f-100?
Old Nov 24, 2011 | 05:08 PM
camperspecial65's Avatar
camperspecial65
I think so but I dont have my parts book in front of me at present. How much are they asking for it?
Old Nov 24, 2011 | 05:21 PM
jowilker's Avatar
jowilker
No the floors are different because of the I-beam change in 65. 61-63, 65-65 are alike.
Can one make one work, I'm sure it can be done, although not bolt up.
John
Old Nov 24, 2011 | 10:53 PM
fila5716909spruce
Newbee got sidetracked.
Thanks for the input , a friend is thinking about this swap, I dont know the price , but the 800 cab is represented as near perfect. he is going to see it Friday. I told him the guys on here would know. thanks again , I will update after he see's it.
Old Nov 25, 2011 | 01:28 AM
Buzz44's Avatar
Buzz44
F350 and up cab used the earlier cab design. If you open the door and see an obvious step there it will or should work. If no step or slight step refer to Jowilkers advice. The roof line may differ on a 66 also. The 61-63 used a flatter roofline with no relief indents. If you dont mind that the floor is the more critical of the two differences.
Old Nov 25, 2011 | 01:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The floor pans are different, but this has nothing to do with Twin-I-Beam suspension as neither one a these trucks had it.
1961/62 F100/600: C1TZ-8111135-M
1961/66 F800/1100: C1TZ-8111135-U
1966 F800/1100's also have a taller roof (C6TZ-8150202-A) than 1961/63's (C1TB-8150202-B) and 1964/65's (C4TZ-8150202-A).
Old Nov 25, 2011 | 05:28 AM
jowilker's Avatar
jowilker
Thanks Bill & welcome back. It did not re-read the same way that I read it the first time. I guess my coffee hadn't kicked in.
John
Old Nov 25, 2011 | 06:49 AM
fila5716909spruce
Newbee up early
Thanks to all who replied, will pass along this great info. also, found a running f-350 with decent cab. Updates to follow.
Old Nov 25, 2011 | 05:58 PM
garbz2's Avatar
garbz2
The F800 cab may have what is called the high roof about six inches higher than a normal roof line. It may also have cab mount extensions to allow it to bolt to the F800 frame mounts.
The F350 will be a direct replacement with one exception. You will need to use the 65 66 heater box that came with those year cabs and the fresh air duct. Earlier cabs have the pull type door on the passenger side where as the 65 66 has a triangular manual door and a square to round fresh air duct if equipped.
Garbz
Old Nov 26, 2011 | 04:13 PM
camperspecial65
Thanks Bill...i had forgotten about the roof ht difference.
- cs65
Old Nov 28, 2011 | 11:43 PM
fila5716909spruce
Newbee has no luck
Thanks for the help guys, both the f-800 f-350 cabs were not as advertised, more rust than the one we have. The search continuies.
Old Nov 29, 2011 | 12:10 PM
garbz2's Avatar
garbz2
Where are you located. I have a 64 cab here in arizona that is in really good fair shape and is completely stripped.
Garbz
Old Nov 29, 2011 | 12:35 PM
NumberDummy
"About Me" profile sez: MO
Old Nov 29, 2011 | 01:03 PM
garbz2's Avatar
garbz2
I went and looked after i posted. I have found that that is not always the case as to location.
Old Nov 29, 2011 | 09:39 PM
fila5716909spruce
newbee in kc
The cab search is going on in the kansas city area. My friend is trying to build a 62 f-100 short flairside with a gasser look,while staying usefull. Thanks,i'll pass on the Arizona cab info, he's crazy enough, who know's? I am without anything older than my 91 f-250 460 efi. Itching to get back in it if I can find the right truck. Bye for now, Jack in KC.
