SD or MAF??
Old Nov 5, 2002 | 10:24 PM
reddevilf150's Avatar
reddevilf150
SD or MAF??
Ok, I'm going to get this straight once and for all. Do I have Speed Density, or MAF.
Air Box w/filter -----sensor-----one round tube----splits into two tubes, then hooks to throttle body.
Thanx for the help.
Old Nov 5, 2002 | 11:07 PM
oldblue18's Avatar
oldblue18
SD or MAF??
You have mass air. If you had speed density, you would have two seperate hoses from the air box all the way to the throttle body and no sensor in the hoses.
Jon
1989 F-150 XL- 4x4, 302, M50D
1995 Bronco Eddie Bauer- 351W, E40D
Old Nov 6, 2002 | 07:20 PM
reddevilf150
SD or MAF??
Ok, thanks for clearing that up!!!
Old Nov 6, 2002 | 08:09 PM
PATS2002's Avatar
PATS2002
SD or MAF??
What is the advantage or disadvantage ??? I have a 94 F-150 5.0 which from the description is speed density.
Old Nov 6, 2002 | 11:11 PM
MustangGT221's Avatar
MustangGT221
SD or MAF??
MAF is a little better in accepting mods like a cam/heads/intake and the like. I think they get a touch better mileage or emissions because they were used on CALI emissions 1995 4.9L and 5.8L trucks and all 95 5.0 automatics. SD is a decent system I think, I wouldn't change it costs 700 or so to change and is kind of difficult. Unless you plan on some super mods stay with what you have. The SD is tunable too, they have some SD friendly cams out there and with a chip it can take most head/intake mods. You can put a supercharger on a SD truck and be fine too. But unless your doing some large mods (the heads, intake etc.) you can do just fine with what you have.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Nov 7, 2002 | 11:40 AM
PATS2002's Avatar
PATS2002
SD or MAF??
Thats pretty much what I figured Thanks for the 411. I don't really plan on gettin crazy. I have had the truck from new (I ordered it) IT's pretty quick stock.
Old Nov 8, 2002 | 10:43 AM
SPROCKET's Avatar
SPROCKET
SD or MAF??
Small correction on MustangGT's...I'm not sure what the deal on the 95 5.0 is with s/d and maf because I know a few guy's with 95 5.0's with S/D and some with MAF...all with different variation's on the tranny to some have auto with s/d some have manual with s/d and same with MAF...I'm wondering if maybe the switched to MAF on the 5.0 like in 95 1/2?
Old Nov 10, 2002 | 11:11 PM
reddevilf150
SD or MAF??
That could be true because I know mine was made in April of 95. SO anything is possible.
Old Nov 10, 2002 | 11:31 PM
corlucci's Avatar
corlucci
SD or MAF??
