F250 Overheating
Old Nov 21, 2011 | 08:55 PM
willor's Avatar
willor
F250 Overheating
I have a 1992 F250 PU. It has started overheating. I replaced the rad cap and the thermostat. Still overheats.
I see fluid in the plastic resevoir, but if I look in the radiator cap I don't see any fluid. Should I?
I don't get any heat through the Heater in the cab.
Anyone know what to check next?
Old Nov 21, 2011 | 09:20 PM
White 97 xlt's Avatar
White 97 xlt
Originally Posted by willor
I have a 1992 F250 PU. It has started overheating. I replaced the rad cap and the thermostat. Was there any coolant in the system when you changed the thermostat? Still overheats.
I see fluid in the plastic resevoir, but if I look in the radiator cap I don't see any fluid. Should I? You should see coolant in the radiator!! Not the cap!!!
I don't get any heat through the Heater in the cab. No coolant in the system will cause this..
Anyone know what to check next? Find a qualified mechanic to look at it for you....
See answers in red above..........
Old Nov 21, 2011 | 09:26 PM
willor's Avatar
willor
Why would there be fluid in the resevoir but not the radiator?
Old Nov 21, 2011 | 09:29 PM
White 97 xlt
I would guess someone filled the reservoir and failed to fill the radiator!!
Old Nov 21, 2011 | 09:34 PM
willor's Avatar
willor
Aren't they supposed to be a connected system? If one has fluid the other should
Old Nov 21, 2011 | 09:55 PM
rquinlans's Avatar
rquinlans
after you put in the new thermostat...turn heater control to full heat
run the engine with the radiator cap off
wait until the engine warms up and the level of coolant will drop as the thermostat opens up , top off the coolant , might have to do a number of times. Be careful as it may spit coolant out the top a little before it opens.
This is one way to "burp" the system.
You should be able to see coolant circulating as the level drops also. If not you may have a worn water pump.
After you get it topped off , close and add to the overflow reservoir.
leffie
Feb 6, 2017 04:14 PM
gumboluvr
May 29, 2007 06:23 AM
Nathane
May 12, 2006 10:40 PM
pr95bronco
Dec 24, 2004 09:36 PM
steeldust
Dec 6, 2003 03:13 PM
