1978 - 1996 Big Bronco
95 Computer into a 93 Bronco?
Old Apr 13, 2003 | 07:33 PM
RAzaRazor's Avatar
RAzaRazor
Question 95 Computer into a 93 Bronco?
I was wondering if there is any advantage to putting a 95 PCM into my 93 Bronco.
It seems that improvements would have been made in the software over the 2 years that could be beneficial.
Does anyone know if this is helpful or harmful, or what effects this would have.
Thanks!
Old Apr 13, 2003 | 08:26 PM
bigric's Avatar
bigric
Didn't they go to MAF and OBDII in '95? If that's the case, then I would expect your Bronco not to go if you swapped the computer. But I'm not sure which year Ford moved to MAF; I know they had it in '96.
Old Apr 13, 2003 | 10:16 PM
RAzaRazor's Avatar
RAzaRazor
Nope, MAF was 96 only.
Old Apr 13, 2003 | 10:42 PM
tite4x4's Avatar
tite4x4
I was under the impression for the Broncos that '95 & '96 were MAF and '94 was a mixed year for both MAF and Speed density. I have benn gradually looking into doing something of the same thing on my '90 rig. There is one company other than Ford Racing that has a MAF conversion kit. http://pro-flow.com/ There kit is pretty expensive though Especially since I spent so much $$$$ already on my rig.
Old Apr 16, 2003 | 12:58 AM
steve83's Avatar
steve83
The 5.0L was MAF for CA in '94 & the CA 5.8L was also in '95. Everything but the 7.5L was MAF in '96.
You can check with Ford to see if the PN for the '95 computer is different from yours, but I suspect it's the same.
