Power Steering Flush
Old Nov 20, 2011 | 10:07 AM
chrison600's Avatar
chrison600
Hi all,
I've done a power steering flush before on another vehicle, and want to do the X. The basics I suppose are the same: disconnect the return hose, cycle the starter to pump the fluid through, backfill with fresh until you see fresh coming out of the return hose.
Ok?
A couple of questions:
Is there an oring on the return hose fitting?
What is the best way to prevent the engine from firing (7.3 PSD)?
Thanks!
Chris
Old Nov 20, 2011 | 10:30 AM
jh818's Avatar
jh818
I believe someone from the Super Duty/Heavy Duty forum had a thread on this very subject and also posted a video doing it.
Here is the link...
https://www.ford-trucks.com/forums/1...ush-video.html
Old Nov 20, 2011 | 08:41 PM
chrison600's Avatar
chrison600
Do you know why he disconnected the return hose at the brake booster and not the PS pump? Was it simply because of where he was going to locate the fluid container? I'm thinking about pulling the hose at the pump and using a 3/8" splice running clear hose down to a drain pan.
Also - Why does the pump not circulate unless the steering or brakes are cycled? When I flushed my daughter's BMW, if the engine caught, I couldn't shut it off fast enough to keep the reservoir from being drained. It moved fluid really quickly...??
Chris
Old Nov 20, 2011 | 11:29 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Here is the link...
Thanks for sharing that with him!
I disconnected the line at the Hydro-Boost unit per Ford instructions in the workshop manuals. I am not sure why, but for every configuration of power steering systems that were available at the time, they ALL say remove the return fitting on the booster unit.
That might work, but then you may run into issues with fluid also coming out of the pump. The line from the reservoir is simply a gravity fed line into the pump, which uses fluid as needed.
As for this, I am not exactly sure. To me its seems like there are less moving parts moving less often; a better design IMO.
As a note, more fluid was flushed from brakes than steering. You should avoid steering from stop to stop too quickly, as this is reported to cause damage to the steering stabilizer.
Also, per Ford, do not leave the steering at full stop for longer than 3-4 seconds or damage to the PS pump may occur.
Thank you for watching my video and asking follow up questions.
rcarter301
Sep 4, 2016 01:52 AM
beachcamperf250
May 21, 2014 08:09 AM
jccapri
Jan 16, 2014 03:33 AM
oldbeater
Sep 16, 2008 03:09 PM
swaybar
18
Jun 6, 2008 07:17 PM
