95' hpop leaking???
Old Nov 17, 2011 | 12:57 PM
noshow's Avatar
noshow
95' hpop leaking???
hpop is leaking. I cleaned valley and can see it dripping. its dripping right under the thingy majigger that has the snap ring on it so the other side of nonservicable plug. thinkin its the back plug and the oil is just leaking down hpop and drippin under the thingy ma-jig. question is when its your non-servicable plug, where does the oil usually leak from as this is deff. coming from the left side and only while running
Old Nov 17, 2011 | 07:57 PM
F350-6's Avatar
F350-6
You mean the whatchamacallit is leaking?
Are you talking about the rear plate with the snap ring on it? That has an o-ring behind it, but it rarely leaks. Oil usually just finds it's way back onto the rear plate from somewhere else.
Are you suspecting the "non-serviceable" plug or the rear plug?
The good news is o-rings are cheap. Replacement O-rings for Ford Diesel Engines
Old Nov 18, 2011 | 07:07 AM
noshow's Avatar
noshow
well its dripping from under the rear plate, but i was thinking (hopeing) it was coming from the rear plug and just leaking down and dripping from the spot. ? is where would non-servicable plug be drippin from.............this sob is drippin
Alberta_Mud
Apr 17, 2018 08:53 AM
suzbandit987
1983 - 2012 Ranger & B-Series
Jan 15, 2012 05:11 PM
Drenalin
24
Mar 27, 2010 07:56 PM
mxracer3276
Aug 2, 2009 06:36 PM
