6.9L N/A Performance
I decided while I have everything apart, I might as well spruce up the performance a bit, but without adding a turbocharger.
Right now I'm considering Stan's Long-Tube Headers (but I haven't really heard much about and how well they work) with a true dual side-exit exhaust, and I'm also looking into the Type4 cam. Are there any other mods that can be done somewhat cheaply to bring up the power a bit? What's the consensus on head porting? This outfit offers head porting service for the IDIs:
6.9L / 7.3L IDI Head Porting Service
I know stock on the 6.9L is 170 HP and around 330-340 ft-lbs tq... Is it possible to get 200 hp out of it at the block, and close to 400 ft-lbs tq?
Also, has any one supercharged a 6.9L? I know they fit superchargers to the GM 6.2/6.5. Eaton style blower with a water to air inter-cooler (Lightning setup) would be pretty neato.
All those other little things can help, not gonna give you 200hp though. In fact, with my intercooler, turbo and increased fuel, I might be just about at the 200hp 400ft/lbs of torque range. Not sure though, no dyno.I'd stud it and turbo it and get power.
For what you would spend on the heads for a stage 1 or 2 upgrade (not to mention the add-ons), you could get a used turbo and add instant power, with better fuel mileage. Turbos on these trucks are proven. If you don't go crazy with boost and monitor your EGTs' it will give you unequaled performance, and reliability. My 93 7.3 has all the power I need with a Sidewinder and 3.5" exhaust
Next I am adding a intercooler to try to milk some more MPGs' out of her. The turbo install isn't that hard if you find a complete kit.
Give it some thought.
Mac.
My buddy suggested I build a set up for twins...
I was actually kicking around the idea of getting a set of flanges and assorted bends and building turbo headers... bringing the manifolds up the sides, mounting two turbos on each side above the valve covers with a cowl induction hood to clear. That's about the only way they'd fit. Only thing is, I've never heard of it being done, and I'm not sure how two smaller turbos would work out.
If I were to turbocharge it, I'd be building it from scratch pretty much.
Any thoughts?
It has been claimed that stans headers give little gain by some, guys that have bought them said different, I never used them so can't say one way or the other.
I do know going to larger true duals helps a lot, I also know the driverside exhaust manifold is crazy restricted on the back cylinder, so I have to believe that the headers help.
I still want to know HOW a head bolt went missing.
My buddies had a pretty good chuckle over that. Being Chevy fans, an onslaught of jokes headed my way but all I had to say was... It ran with critical pieces missing. Built Ford tough. I guess more specifically, built Ford tough with International stuff.
The best thing you can do to an IDI, is Turbo it. Supercharging is a waste of energy, and you dont get the load controlled benefits of a Turbo. If your Turbo is not spooling up fast enough for you (Jesus, how low do you want said boost??), its because your setup isnt dialed in. Turbo's are put on almost all diesel engines for a reason, they are the most efficient, and best suited power adder, plain and simple.
To the OP, your best bet would be to Stud it, Turbo it, Cam it and Pump it, youll a lot more satisfaction from that, then to build a "Hi-Po" N/A engine.
if you are not going to run a turbo head studs are a waist of money.
Just a free flowing exhaust and free up the air intake makes a lot of difference in these engines.
People have to keep them a long time to make it actually worth while to spend the bucks, a turbo and related parts cost, and many don't keep them that long.
Turbo's are really not that bad. I couldnt sell my factory ATS kit, COMPLETE, for more than $500, and you can sink that into useless N/A upgrades in no time.
All im saying is a Turbo is the most bang for the buck, and thats un-arguable.
There are a lot of people that don't need to spend the bucks for a turbo, that can benifit from some cheaper upgrades.
Personally, I like the idea of a turbo, but I also like the simplicity of a naturally aspirated engine and the fact that there isn't much room to work under the hood once you've got a turbo on there. Unless you remotely mount the turbo/turbos, and seems to me that would have it's own unique set of problems, like oil routing and return. Also, most of the turbo kits that are used that I have personally seen for sale, seem pretty beat for that price range ($500-$1000) and may or may not be missing components.
It just seems hard to believe that with a cam, headers and a full exhaust, 20-30 HP couldn't be tacked on. It's been said that the Type4 cam will give you close to 12% increase in power, and at a lower power band... So right there that takes a good running 170 HP up to ~190 HP. Of course this is on paper.
Remember, I'm also talking about getting 200 HP at the block, not rear wheels.
I am sorry to you racindrummin. I totally misread your handle and ment no disrespect or surely wasn't trying to insult you. I didn't even notice it until fiftyfordfloored pointed it out.
At least now I know why you thought I was trying to insult you.
