I recently purchased a 1961 Ford F100 Unibody. It is a California truck and was since new. I have a couple of questions. I am looking for the upper steering column bearing retainer (3-speed on the column). Also what were the tire sizes and options for tires for that model year? Thank you for your help...
Minuteman Ford Truck in Walpole have both of them...you need 1 of each for your '61
The sleeve is what the bearing rides on...like a race if you will...They have 3 of the sleeves and 2 bearings
Tire sizes...If you are referring to the old type letter type sizes I dont know what the size would have been.
The bearings are an assembly...they ride on on a nylon sleeve on the steering shaft as I recall...i have one of the bearings in front of me too...Is your column apart ???
not sure about the 61 but my 65 f100 came with 7.00 x 15 LT tires on it. they are what I am still running I have two traction tires on the back and 2 highway on the front. My speedo is right on the money with this setup. I find that the bias tires work great and make the truck steer better than with radials.
For whatever reason (hoarders)? I collect good bias ply tires. OK, rims too. I sell or trade them cheap. I live in NW Washington. Have good 700 15 traction on ford 1/2 ton rims both excellent. I mess with a lot of old fords and I always feel there's "somebody out there that needs these", besides it costs me 8.00 a piece to take them to the dump so they kinda build up........
One fortunate thing about this size of Ford pickup is that the wheels
and tires stayed very similar for a lot of years like from is it 1948-1996?
so unless you want to be picky about being true to the style that it
came with there are all sorts of different wheels that will work.
235/75/15 is a very common size and is about 29" tall.
Most trucks in that 40 years were about 29"-30 high, I think.
I like to use these tire size calculators like the link below because after that
"cash for clunkers" thing a few years ago there seems to be a sort of cottage industry for reselling nice used tires where I live, for $20-30 each and I can change a set with my old manual changer in a half hour.
To keep your speedo close just keep it near 29"
If you use this calculator, and are comparing a bigger tire first to a smaller second tire it will even show far off the speedometer will be.
Tons of sites like this one.
Any chance that you would have 2 16" 5 on 5 1/2 innie Ford wheels that you would want to sell. I am in need of those from the 61-64 years. rim width would probably be about 5 to 5 1/2
