Need Help!
Old Nov 15, 2011 | 07:20 PM
Death85e's Avatar
Death85e
The coil should have a solid 12 volts going to it when cranking if i am not mistaken. After it starts it will return to the lower voltage due to it going through the resistor wire.
Old Nov 16, 2011 | 08:13 PM
finneys98xj's Avatar
finneys98xj
OK I jumped the coil and she got the spark need to crank her. But before I could get her cranked and timed the solinord burnt up. Any ideas as to what is wrong?
Old Nov 17, 2011 | 04:45 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Looks like the ign switch needs to be replaced so you can loose the jumper.
If you are referring to the starter solenoid you must have been cranking the starter too long. 30sec rest then again. You can burn up the starter motor cranking the motor too long at one time. Did it try to start? When you are at the top of the compression stroke for the #1 cyl is the rotor pointing to the number one spark plug post?
Remember you need fuel, spark and for the spark to happen at the correct time.
Let us know of your progress.
Old Nov 17, 2011 | 06:15 AM
i-w's Avatar
i-w
does the dizzy have a good ground?
had a friend once kill 2 batteries because
the dizzy ground was not connected.
could be apples to oranges.
Old Nov 17, 2011 | 06:16 AM
finneys98xj
Yea she fired up for a few seconds. I think she still maybe 180 out but I need to get the coil firing right first so I can get her to run to get it timed. I'm going to pickup a switch on the way home this evening and hope that does the trick.
Old Nov 17, 2011 | 06:23 AM
finneys98xj
Yes it does. The only wire I UN hooked was the plug at the dizzy. And with the coil jumped it fires llike it is supposed to.
Old Nov 17, 2011 | 04:57 PM
finneys98xj
I have to exchange the new switch cause the new one is messed up. But with the new seliniod it all it does is buzz(seliniod) and the dizzy hums alittle. The motor aint turning over?
Old Nov 17, 2011 | 05:32 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Sounds like the battery is discharged. Since there are issues with the ign switch disconnect the battery ground and put it on a charger til you replace the ign switch. I don't know what the "humming" from the dist. would be. You didn't leave the jumper hooked up did you? See what happens tomorrow when you replace the switch and have a fully charged battery.
Old Nov 17, 2011 | 05:36 PM
finneys98xj
We had jumper cables hooked up to the truck. and was getting 13.63 to the battery side of the seliniod and about 5 to the starter side.
Old Nov 17, 2011 | 05:52 PM
OldStyle's Avatar
OldStyle
Rusty Roller
I thought you said the solenoid smoked yesterday while trying to start the motor? It needs to be replaced also.
Old Nov 17, 2011 | 05:55 PM
finneys98xj
Thats with a new one!
Old Nov 17, 2011 | 06:16 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Well that's not right.... Try cleaning the battery posts and charging the battery instead of jumping. You have to wait til tomorrow for the new ign switch so wait till you have it all in place and see.
Old Nov 17, 2011 | 06:19 PM
  #28
finneys98xj
I'm going to wait. I dont want rush it
Old Nov 18, 2011 | 06:16 PM
  #29
finneys98xj
OK Fixed all the problem with this go around with the switch!!!
Tomorrow when I get out the woods(opening day of firearms) I will get her in time and broke in!
THANKS TO ALL WHO HELPED!!!!
Old Nov 20, 2011 | 04:56 PM
  #30
finneys98xj
Problem is back!!
Could it be the pick-up in the dizzy?
