Clay is paying me a great honor right now.
#31
#32
Hey Dan,
How does the intake get so plugged with soot? Just poor maintenance?
Clay, Throw away that Chiltons manual and get yourself a Robert Bentley in stead!
My 1981 Rabbit pickup 1.9 n/a diesel still gets 42 MPG after 200k miles on the truck. Just glad I'm not in hurry!
Nick
Nick
I am not getting this to work on it anyway. Hence the reason Dan has it
#33
#34
Thanks, I was looking at Kerma (also has hot swap program) PP520, Sprints and the Titan 520. Trying to decide which is the better choice for me. Not looking at upgrading turbo, exhaust etc.
I am looking at stage 2 tunes (a few months after injector replacement) and just had a new vr6 clutch installed.
#35
Hey Dan,
Nick
Nick
The EGR valve combined with the oil mist from the crankcase breather makes the all that buildup happen over time.
I'm doing a CCV mod for Clay so that will cut way down on the buildup.
If I disable the EGR then the check engine light will come on, so the CCV mod is a good way to eliminate this problem.
Teflon coated 100,000 mile timing belt, changing injector nozzles, and various shots of the engine in different states of dissassembly.
Finishing everything up today and taking the car down to the alignment shop tomorrow.
Click on the picture and you can see the rest of the photos.
#37
#38
Nice try.
I thought they were chains now.
I'll have to look into that.
If it's still a belt, I wouldn't go past 80k.
Just had a customer come in last month with 90k on his original belt and it failed, ruining the motor just like that one I posted about on Facebook.
He didn't have the money to fix that one so he had it towed home for now.
For my own vehicles, just to be safe, I do them every 50k, but that might be a little overkill.
On my own TDI I've racked up 30k so far since I did mine and plan on changing it out at 50. Just the belt this time around, all the rollers should be good.
The next time, if I still have the car, it will be a complete job like I'm doing for Clay right now..
Ok, back to work. Need to finish up Clay's car for Saturday delivery.
#39
#41
Looks like I have a long future ahead of me doing timing belts.
I really thought they were timing chains by now.
Taking a quick dinner break, got the engine running, still need to set the pump timing.
You can see the CCV mod that I put in about halfway through going up over the intake.
ClayJettaTDI.MOV - YouTube
#42
Dont forget you got a TDI specialist down here in socal.
Dan, The current TDI still sports a timing belt and in my opinion is even easier than an ALH motor belt. You dont even need to loosen the engine mount. As far as modding a 09 and up I would not recommend doing anything to them other than a ecm reflash ( I have a neuspeed flash in mine that is suppose to add about 25hp). As far as the soot/gunk in the older tdi's it seems to happen more when people drive them around town for short distances and never drive them for a long distance or past 1/4 throttle.
#44
#45
I'd like to add to this if you don't mind and state that I agree with Dan. The 1.8l turbo sitting in my driveway smoked the timing belt 2k miles past warranty, granted it's not diesel but an interference motor none the less. It's the first foreign front drive vehicle to ever be parked on my property so I didn't know any better at the time... though I should have. Even though I did all the work myself, all the parts added up to a huge chunk of change. Enough that I could have done some major mods to the Powerstroke. Needless to say, it gets changed every 50k now.
