Dana 70
Old Nov 15, 2011 | 09:00 AM
vettman's Avatar
vettman
Dana 70
I have a Dana 70-B with 4.10 gears in my 1976 F-350. Can someone tell me if this diff has a single piece carrier, or a 2-piece carrier. It is not a limited slip.
Thanks
Old Nov 15, 2011 | 05:38 PM
RunninD's Avatar
RunninD
Both! Unfortunately there are about 6 styles for the D70's which include options which use the D60 bearings and seals too. The only way to know for certainni what your axle is would be to tear it down. The Bill of Material (BOM) should be stamped on the top of the axle tube that number will tell you what variant of D70 it originally was, which will tell you which seals, which bearings and which carrier. see this link for much much more!! Dana 70 Solid Front & Rear Axle info
Old Nov 15, 2011 | 05:48 PM
RunninD's Avatar
RunninD
Some Specifications on the Dana 70:
  • Max gearing is a massive 7.17:1
  • Excellent Locker Selection
  • 1.5” 35 Spline Shafts
  • Max Torque Rating: 8,000 lb-ft or 8,800 lb-ft for the HD
  • Nodular Iron Housing
Old Nov 15, 2011 | 06:03 PM
vettman's Avatar
vettman
Thanks, RunninD; that's some good data. Will the code stamped on the right side of the axle shaft tell me if I have a 1-piece or 2-piece carrier? Is there a site that will interpret the code for me? What I'm trying to do is upgrade my Dana 70-B with a PosiTrax traction system. I spoken to tech support at Richmond Gear, and they need to know the carrier type before they can give me the correct part number.
I'm not sure I understand how to tell if I have a 1-piece or 2-piece, even if I had the cover off.
Old Nov 15, 2011 | 07:01 PM
RunninD's Avatar
RunninD
If it is not a Limited slip then I believe that it will be a One piece carrier, but to be on the safe side here is a bit more info for you to try.
http://www2.dana.com/pdf/XGI.pd which is a Dana site, and
Dana/Spicer Bill Of Material Numbers which gives a run down of the various numbers yours is probably in there.
Old Nov 15, 2011 | 07:14 PM
vettman's Avatar
vettman
Thanks again, RunninD--more good data. FYI, the first link you listed does not work for me, but the 2nd link has what I wanted.
Old Nov 15, 2011 | 08:28 PM
RunninD's Avatar
RunninD
glad to hear it
Ken(Ark)
Dec 26, 2021 01:28 PM
Pesch
Apr 27, 2016 08:34 AM
amcv8jeep
Sep 28, 2007 12:09 PM
fourfoot23
Jun 6, 2004 09:26 PM
bigf150
Apr 18, 2003 08:14 AM
