Is adding an Overdrive a good thing ?
Old Dec 26, 2012 | 10:37 PM
fifty-two_f1's Avatar
fifty-two_f1
you are getting 12.3 mpg?? with 3.73s and an overdrive?? Are you sure you are calculating properly (not saying that you cannot add) but that is a sweet setup for gearing. At 55 mph you should be running perfect economy rpms...
Old Dec 28, 2012 | 07:34 PM
56f1hundred's Avatar
56f1hundred
Does anyone know if the Bendtsens adapter can be used in a truck with the original engine mounts or do you have to install side mounts.
CheeksMcDuke
43
Jan 21, 2010 01:52 PM
Bobs55effie
Jun 30, 2008 01:44 PM
AmeriKen
Jun 29, 2006 10:55 PM
bigwheelin
Jan 17, 2006 09:45 PM
64_f100_owner
Jan 17, 2004 11:55 PM
