Sponsored by: Real Truck
factory antenna
Old Nov 13, 2011 | 11:34 PM
budman325's Avatar
budman325
factory antenna
Is there anything I can do to modify my radio antenna to work better, I get a lot of static every now and then, stations fading in and out, etc. or is there a anything aftermarket that would work.
Its a 2004 F350
Old Nov 13, 2011 | 11:45 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
In line noise filters. They are supposed to do good work.
Old Nov 14, 2011 | 12:05 AM
TRENT310's Avatar
TRENT310
That depends on if the antenna is the problem in the first place. You may not necessarily be able to add devices to solve a problem of something missing in the chain.
It could be the connection between the antenna mast and the coax, it could be in the coax itself, or it could be a problem in the radio head unit.
What radio band are these problems occurring? That should begin to narrow down what kind of noise problems you are having.
Old Nov 14, 2011 | 06:52 AM
Hotpocket's Avatar
Hotpocket
also cheap aftermarket radios are not as sensitive as better ones..
Obowersox26
May 16, 2016 01:47 PM
brd7666
Dec 4, 2014 07:52 AM
ssanto
Dec 17, 2006 06:10 PM
brosko80
Feb 28, 2006 07:24 PM
trakman
Dec 19, 2004 08:00 PM
