1998 F-150
1998 F-150
Hi Dave,
Thanks for the welcome
The engine misses after it warms up, almost to stall point, and only under load while transmission is in drive with vehicle stopped. Engine runs fine at idle/neutral and acceleration. The “check engine” was activated with a too lean condition; I then replaced the two front O² sensors. Seems to run better but problem persist. No other symptoms.
DKH
DKH
1998 F-150
You might have more than one problem.
It sounds to me like you might have an IAC problem. You can try removing it and cleaning it to see if that makes a difference. It is bolted to the top of the intake manifold with 2 bolts. You can clean it with some Carb Medic carb cleaner.
While you're cleaning things you should clean the MAF sensor as well and check for air leaks between the MAF and the throttle body. To get at the MAF you remove the air cleaner housing like if you were changing the filter. Take a look in the hose that goes to the throttle body on the engine. You will see a rectangular shaped piece with 2 thin wires that look like light bulb filaments. Clean these with some Carb medic as well. Usually spraying them will clean them off. You want to get rid of any "fuzzies" on them but you dont want to actually touch them with anything much as they break quite easily.
You might also want to check for a vacuum leak. Check all your vacuum hoses and see if they are all attached and not cracked or anything. You can take some Carb Medic and with the engine iding spray it at the intake manifold where it bolts to the heads, where the throttle body bolts to the intake, at any vacuum hoses etc. If the idle changes at all, either up or down, you've found a leak.
Let us know what you find.
1998 F-150
I cleaned the sensors and the IAC, I then did a vacuum leak test with contact cleaner and I found a small house on the intake manifold directly opposite of the IAC, which had a 3/16 hole in it. Since I didn’t have a replacement hose with me I patched it with a radial tire patch. Engine runs smooth now. Thanks very much for your help. I owe you one. If you ever need any CAD work done, let me know.
DKH
DKH
1998 F-150
CAD work eh? hmmmmm
lol
One of these days I want to draw out the front suspension of my race car to figure out the roll center, camber curves etc.
If there wasn't good instructions in books for doing that I might take you up on your offer
Good to hear that you got your truck running better again
Thanks for letting us know what you found.
lol
Shelbynut
04-02-2014 10:26 PM
