well the evil white stuff is here again, now we got windows that are froze shut.. is there a trick it seems they freeze in the tracks or somthing around the door frame.
i tried the banging, the only thing that works is the ice scraper. but the reason i want to open them is its a pain in my azz to get my fast food and ice creams at the drivethru!
Try getting closer to the equator. Alas, the evil cold is creeping in here too.
A little silicon spray around the seals helps some, but for the most part it's just another reason I am not a fan of winter.
Yes, Silicone spray is the answer once you get it thawed out.......I use it on the door rubbers to keep the doors from freezing shut, and the rear hatch since it likes to stick fast ....and in the outside groove of the front factory hubs to keep them turning easy.
DO NOT spray it in the same building you are painting anything in.....fisheye city
ok i got the silicon spray, sprayed the window tracks door seals the whole works. probably wasent smart to spray the door window wipes, but they had a buncha ice in them sticking to the window causing it to not open. but makes the windows harder to see outa. guess i could just roll them down now and drive.
