Alternator / Battery Charge - HELP
Old Nov 10, 2011 | 05:33 PM
Aerostar1993's Avatar
Aerostar1993
Question Alternator / Battery Charge - HELP
Replaced the alternator and battery in my 1993 Aerostar van... but now the alternator doesn't seem to be charging the battery at all.
The connections (wires) are all good / tight. I just can't locate the problem.
Any suggestions on the likely source of trouble?
Thanks in advance!
Old Nov 10, 2011 | 06:57 PM
Franklin2's Avatar
Franklin2
With the van off, check for 12v on the large battery output terminal on the alternator. If you do not have 12v, you probably blew out the fuse or the fusible link on this output wire, whichever your van has.
Old Nov 10, 2011 | 11:25 PM
Aerostar1993
Thanks alot for the reply!
I checked the output of battery with van off, it's at 12. I looked for a fuse but all in the fuse box are good. Not sure about a fusible link on the output wire. Where would that be located on the wire? When I looked at the owners manual about the fuse it said the location is the starter motor relay. I'm unsure which of the four relays it is.
Old Nov 12, 2011 | 07:49 AM
Franklin2's Avatar
Franklin2
The starter motor relay will be a large solenoid mounted under the hood, not a small black box relay. The fusible links are rubber things made into the wire. But if you have 12v, you should be good. You should also have a fuse for the regulator circuit in the underhood fuse box, but you said all the fuses are good.
Have you measured the battery voltage with the engine running? What is it?
1sraider
19
Nov 28, 2018 04:32 AM
Bubba Hines
Dec 19, 2015 09:06 PM
72camperspecial
May 28, 2013 09:12 PM
92-B4000
1983 - 2012 Ranger & B-Series
Jun 7, 2009 07:26 AM
rangercld
Oct 21, 2004 12:14 PM
