1970 ford crewcab restoration, wyoming.
Old 10-22-2014, 09:10 PM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
Rear seat
Originally Posted by grinnergetter
Thanks for the info...my 72 came with a 60/40 split(bronco I guess) and the what appears to be the stock rear seat. I dont think the rear had quite that much space. 15" is a ton.
Yes I looked around for awhile before picking this 2011 extended cab truck. Looked at some bronco stuff but wrong setup. Plus the weight of the older seats is something to consider! Put my old truck on a diet! Will be weighing my truck this weekend! Get fuel mileage any way I can with 3/4ton.
  #92
Old 10-25-2014, 11:25 PM
wyoming4x4's Avatar
wyoming4x4
Skinny crewcab!
Weighed truck today, 6200lbs. Was hoping for less! Hoping for 5500lbs. Still better than original weight. Over 7000 in original form! I'm about 500 lbs heavier than my target weight..
  #93
Old 10-26-2014, 10:15 AM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
That's more then I was figuring on weight to but a 4wd can become heavy real quick. I'll have to see what mine weighs after it's all together. I'll be in the 7,500 range in guessing. Your back seat helps with the rear leg room which these trucks suffer in the back.
  #94
Old 10-26-2014, 04:07 PM
wyoming4x4's Avatar
wyoming4x4
Rear seats install upholstery done.
Bolt in seats today looks nice and dog proof. Hair won't stick in material. Gonna have some seat covers also for protection. Seat to door clearance is 10" with down. 20" up clearance.
  #95
Old 10-26-2014, 04:12 PM
wyoming4x4's Avatar
wyoming4x4
Rear seats install. 2011 ford extended cab. Looks nice!
2011 ext cab seats in 1970 crewcab.
  #96
Old 10-26-2014, 04:15 PM
wyoming4x4's Avatar
wyoming4x4
Rear seat install.
  #97
Old 10-26-2014, 07:57 PM
crazed87bronco
Awesome space back there. The upholstery looks great to.
  #98
Old 10-26-2014, 10:02 PM
wyoming4x4's Avatar
wyoming4x4
Lock up seats are a nice!
Lock up seats are great for when packing gear! Keeps my gear warm and dry. This is my soon to be archery truck, travel around and shoot tournaments all over!
  #99
Old 10-26-2014, 10:09 PM
wyoming4x4's Avatar
wyoming4x4
Front suspension link with fox race shocks 3.0.
Was a leaf spring truck now a linked front suspension coil spring truck!
70 ford f250 4wd. Linked Dana 44.
  #100
Old 10-26-2014, 10:14 PM
wyoming4x4's Avatar
wyoming4x4
Limit straps still need to installed and just about done with front suspension. Some more tuning on fox shocks. Ride a little stiff and will be worked soon!
  #101
Old 10-26-2014, 10:15 PM
wyoming4x4's Avatar
wyoming4x4
Headers will be sent to jet hot once everything tuned in.
  #102
Old 10-27-2014, 10:12 AM
crazed87bronco
What made you go with the 3.0 fox shocks over the 2.5's? I'm thinking of the 2.5's for my rig just wanted to see if I should be going with 3.0's instead.
  #103
Old 10-29-2014, 07:32 AM
wyoming4x4's Avatar
wyoming4x4
Fox shocks!
3.0 or 2.5? Both are capable of doing what I need but I like overkill, so 3.0 work! I often run dirt roads in wyoming for up to 50+ miles and they just beat the hell out of a truck! So in my situation overkill was for me.
  #104
Old 10-29-2014, 07:36 AM
wyoming4x4's Avatar
wyoming4x4
Matching trailor with 70 crew!
  #105
Old 10-29-2014, 08:07 AM
trozei's Avatar
trozei
trozei is offline
That's one of the rare times I've seen a late model seat not look terrible in and old truck. Good job.
Quick Reply: 1970 ford crewcab restoration, wyoming.
