Axle Ratio
Old Apr 11, 2003 | 09:08 PM
sandpiper's Avatar
sandpiper
Axle Ratio
I bought a used 2000 F150. Have some desert toys I'd like to tow. Everything I've researched up to now points back to the one item that I need to know but don't. How can I find out what my axle ratio is?
Old Apr 11, 2003 | 10:21 PM
nafzimo's Avatar
nafzimo
Axle Ratio
The ratio is usually stamped on a tag on the rear end. Or, there will be an axle code on the plate on the drivers door. Get the code and some one here should be able to decipher it.
Matt
Old Apr 12, 2003 | 01:39 AM
sandpiper's Avatar
sandpiper
Axle Ratio
Thanks Matt. I checked the id plate on the inside of the door but it didn't have the info. I will check the axle itself tomorrow. If that does not work does anyone know a website maybe back at Ford where I can give the VIN number and they can tell me?
Sandpiper
Old Apr 12, 2003 | 09:47 AM
StrangeRanger's Avatar
StrangeRanger
Axle Ratio
It's not in the VIN. There should be an "axle" code on the vehicle ID sticker at the center bottom, if not then there's the code on the rear end tag. If all else fails, jack it up and turn the wheel by hand and count the axle revs.
If you have a limited slip, you'll have to raise both rear wheels off the ground and the number of driveshaft turns to get ONE rotation of the wheels is the rear end ratio. If you have an open rear then jack only one rear wheel off the ground and the number of driveshaft turns to get TWO wheel revs is your ratio.
Old Apr 12, 2003 | 03:00 PM
sandpiper's Avatar
sandpiper
Axle Ratio
HERE'S WHAT I GOT OFF THE TAG
3L55 88 0D06
AM I READING THIS TO BE 3.55 AXLE RATIO?
SANDPIPER
Old Apr 12, 2003 | 05:12 PM
StrangeRanger
Axle Ratio
You're in luck. It's a 3.55 limited slip. The chances of finding one with that combination by random luck on a used car lot are pretty low. Just for grins take another look at that vehicle ID sticker see if there's a code "H9" for the axle.
Old Apr 12, 2003 | 08:56 PM
Tonytheman's Avatar
Tonytheman
Talking Axle Ratio
Strangeranger
Are you saying that H9 is the code for a limited slip differential and 3.55 gears? Or just 3.55 gears?
In your experience how common is this set up. The axle code on my used 2001 Screw is also H9.
Old Apr 12, 2003 | 09:44 PM
StrangeRanger
Axle Ratio
H9 is 3.55 LS
19 is 3.55 open
Most trucks have open rears, don't ask why
Old Apr 25, 2003 | 02:42 PM
ClydeSDale's Avatar
ClydeSDale
Axle Ratio
Open rears are cheaper to build with a much lower maint. requirement.
Open rears are usually standard equipment.
Most people don't understand the value of LS so don't order it.
Most people don't even know what their axle ratio is.
Most people don't even know what an axle ratio is.
You are indeed lucky to find a LS on a lot.
Have fun with it.
Old Apr 28, 2003 | 11:07 PM
sandpiper's Avatar
sandpiper
Axle Ratio
To all:
Thanks everyone for the info. This is truly a great way to get info and opinion. Looks like I got everything I need to determine my tow rating. Just need to find the right toy hauler.
Thanks again
Sandpiper
Old Apr 28, 2003 | 11:52 PM
PSD_Power's Avatar
PSD_Power
Axle Ratio
hmm, toyhauler. You need a bigger truck. This is my toyhauler....
1955 f250
Oct 14, 2014 09:24 PM
KLEO1480
Mar 2, 2013 06:53 AM
lwclark
May 1, 2012 06:28 AM
nash22
Oct 12, 2011 07:58 PM
truckmonger1
1997 - 2003 F150
Aug 30, 2009 06:47 AM
