Gearing ratio?????
Old Apr 11, 2003 | 03:50 PM
no name's Avatar
no name
Gearing ratio?????
I have what appears to be a 10.25 rear end with a tag marked V108C 73 10 2 7F0L on my 87 F250. I need to determine what the gear ratio is. Can anyone help me?
Thanks
Old Apr 11, 2003 | 08:15 PM
MustangGT221's Avatar
MustangGT221
Gearing ratio?????
There seems to be a few numbers missing, the 73 in the middle leads me to think "3 73" (3.73 open diff) or "3L73" for limited slip. Try posting the axle code from the door jam stick, might have better luck with that. The "10 2" seems like "10 25" which is what axle you have.
Old Apr 11, 2003 | 09:05 PM
no name's Avatar
no name
Gearing ratio?????
Thanks for the reply. Unfortunetly' I have a '94 cab on that chasy so the tag on the rear end is all I have. The tag is in good shape and I'm sure that is all that was on it. No missing info. I guess that I can get out there and turn the axle by hand . Any instructions for how to do it?
Old Apr 12, 2003 | 02:35 AM
pbrstreetg's Avatar
pbrstreetg
Gearing ratio?????
Hi-
get some black spermatex, take off the cover, count the teeth, ascertain open/ls status, and most importantly CHANGE the gear oil
