1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
xrf balljoint input
Old 11-03-2011, 12:49 PM
ryanc74's Avatar
ryanc74
ryanc74 is offline
xrf balljoint input
Has anyone tried the balljoints form xrf? i know the million mile warranty is probably too good to be true, but if they are a more stout piece then might be worth it. Has anyone tried these and if so what did you think? Its time to do mine and since this will be the second set in 95,000 miles, it would be worth it to find a lomger lasting part.
Thanks
Old 11-03-2011, 04:51 PM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
A buddy of mine brought over a full XRF front end set for a Chevy Tahoe. It's all made in China. The parts went in fine, but they provided grade 8 bolts/nuts for the upper ball joint (which is bolted to the control arm), and ungraded washers. When you tightened the bolt/nut to spec, the flimsy ungraded washer squirted out the side all mangled.
This wouldn't be the first time I saw a manufacturer provide graded hardware, but ungraded washers, but it was inexcusable. We used some old metric Toyota washers that were up to the task.
I'm not sure the joints were any better or worse than anyone else's joints.
Old 11-03-2011, 05:15 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
I did the XRF ball joints and complete tie rod kit about a 8 months ago. everything is still good at this point. about 15k on them. grease-able ball joints.
The only thing i found was on the XRF front drag link where the steering stabilizer bolts around it. the stock ford one has grooves for the u-bolts. XRF dose not.. you have to hammer them over the link to open them a little more, then bend the u-blot to go back through the mount plate holes.
Yes i was a little skeptical but so far so good....
I think i payed $399 for everything..
The Link where i got mine. The Tire Club
Old 11-03-2011, 05:59 PM
hammer65's Avatar
hammer65
hammer65 is offline
I believe that XRF Joints are what I used. About 1500 miles now and no known problem.
I think I got them from the Tire Club
pin8246
04-26-2013 11:22 PM
00Dave
48
06-22-2011 12:22 PM
brian42
05-07-2009 02:15 PM
oops
1983 - 2012 Ranger & B-Series
03-10-2007 08:25 PM
devozoo
1997 - 2003 F150
13
02-12-2007 11:24 AM
Quick Reply: xrf balljoint input
