460?
L&L Products
There maybe some parts here that could work too
AdvanceAdapters.com | Engine & Transmission Conversion Adapters - Advance Adapters
If you're looking for an auto trans hit up your local junkyard and find a C6 from a late 70s Ford 4x4 truck. It can behind a 460, 400, or a 351M. Grab the transfercase too.
the torque converter can be used as well
the 429 from the lincolns have a smaller diam pilot in the end of the crank so the tq converter from the other c6 trans wont interchange (use the tq converter thats from the same lincoln the 429 come from)
the engine mounts form the 351m wont interchange
BUT they make adaptors to put 460s anywhere you want
the np208 already in your 93? should bolt up to the older c6
the np205 on the 77 c6 trans is a monster...but not really good for hyway use around town and mudding and abuse is perfect though (can be made into a twin stick xfer case make sure you change fluid in it though)
460s respond very well to any mods
yank it apart quick swap the cam (the bigger summit cam is very nice) and gearset, mark the valves and pull them out, give the ports a nice cleanup and blend job EXPECIALLY where the exh valve seat is lots of extra junk still in the heads
older small chamber heads have studs already, buy new studs and guideplates and roller rockers (old rockers are cast and ive broke a few of them). newer heads are pedistal mount and are decent rockers, but you can buy bolt down roller rockers for that as well (pedistal mount rockers) performer intake will make over 450hp and give a fantastic low end (ive done it) but the performer rpm is a nice upgrade in mid and upper end hp weiand stelth is a little much for a towing rig cause it does zero for low end tq (but ive used it a lot against what ive just said)
headers.... whatever you want just remember not to use headers from an efi engine youll need to buy headers for the 87 and older carb truck (the efi heads are hiport and exh ports dont lign up with the old heads)
stock truck with stock 625 holley and you want more
or does it have an aftermarket intake or exhaust or anything i should know about
What kind of "pep" are you refering to... quicker throttle responce or more tq range, higher rpm. What do you do with the truck
Personally, if it were a stock intake, id say give it a 2" tall 4hole carb spacer with the stock carb, and put a k&n in the stock aircleaner (sleeper look and it gets plenty of flow with the big hole in the back)
I run a modded spreadbore 850 holley on my jetboat with a stealth intake...rev it 7k all day long, and run a 700 double pump on my plow truck with a zf5 and the big summit cam and an edelbrock streetmaster intake (awesome intake for torque by the way)
stock intake isnt that bad for torque and works fine up to 5000, not saying you wouldnt gain from a performer or street master but its ok if not in the budget.
Passenger Car 460's and F100/350 & Econoline 460's prior to mid-year 1979 are internally balanced.
Thunderbird...sorry. I get them confused. Both are big and ugly and similar shaped.
Junk guys bring me the cars to strip of engine and trans and rear axle and then haul the rest away.
69/70 with the dove-c heads. And c9ve heads. Small combustion chamber.
All I can remember on rotating assy is that if there is a half moon weight behind the harmonic damper then you need to use a specific flywheel. And if you have an efi 460 it also uses a different flywheel.
Other then that they can use the same flywheel/ flexplate and it will interchange with the fe flywheel/flexplate from a 360-390.
The 429/460 block casting numbers used 1968, 1969, 1970 & 1971/73 were the same.
The 1971/73 block casting number was also used thru 1978 and on some 1979 F150/350 & Econoline 460's: D1VE-6059-AB
429: 1968/71 Ford/Merc Passenger Cars & Thunderbird / 1972/73 Ford/Merc Passenger Cars.
460: 1968/78 Lincoln & Continental Mark / 1972/76 Thunderbird / 1973/78 Ford/Merc Passenger Cars // 1973/76 F100/350 / 1975/79 Econoline / 1977/79 F150/350 (except 1978/79 sold new in CA F150's).
FoMoCo changed the 460 mid-year 1979, has a weighted spacer. Since this was a "running change" there is no before/from a certain serial number or production date. The block casting number is D9TE-6059-AB
The flywheel and harmonic balancer used with the D9TE block are different from the D1VE block.
No 460's in E100/150's and F150's after 1979. No 460's in 1980/82 F250/350's, E250/350's only.
1983 was the first year FoMoCo offered the 460 with M/T and 4WD, F350's only initially.
See my signature, I didn't start doing this jazz yesterday.
I just noticed your sig... I have no doubt you've looked it up a few more times then I.
What's different on the d9 balancer and flywheel. Is that the one with the crank driven ps pump.
The D9 beginning in 1979 went to an external balance, but as a side note, this rotating assembly can go into all the earlier blocks, but not visa versa, I believe.
I read the numbers wrong. You said d9 then d1 and I thought c9.
I am interested in the years the crank driven ps pump was. It's the older years I know but I'm having trouble finding the years to look for and which cars. It was driven off the crank snout behind the balancer. Instead of the spacer sleeve the pump went there and bolted to a specific timing cover as well.
Anyway. Great info. Thanks.
