Window felt question (inner felt inside window)
Old Nov 2, 2011 | 12:36 AM
marine1200's Avatar
marine1200
I pulled off all the felt trims and the rivets that hold them in place.
-Top window felt (where the glass comes out of)
-Rubber where the glass sits (window trim)
I notice the inner window guides have felt on them as well. The rails that guide the windows up inside the door. How do I change them out?
Im hoping people dont say cut the door open
Old Nov 2, 2011 | 09:18 AM
COMPLIT1107's Avatar
COMPLIT1107
Go on a moderate diet to make your arms skinny and flexible......
Then remove the inspection panels from the door to remove the felt. It has a flex metal backing with a clip on the bottom. If I remember correctly, there may be a screw or clip at the top, just at the window opening in the door. Be careful with the inner door rails! Pull the felt "U' out of the rail from the top down, then the bottom clip will release.
P.S. Sometimes some adhesive may have been used. I don't think that it was "factory"
Old Nov 2, 2011 | 10:52 AM
marine1200's Avatar
marine1200
Thanks I figured...now I need to go find a really long screw driver..there is no way Im gonna get my hand all the way in there.
Fordby4
Jul 26, 2010 09:32 PM
jck_strw
Oct 17, 2009 03:58 PM
FORD MEGA CAB!!!
Dec 5, 2008 11:18 AM
68GTCS
Nov 10, 2004 10:03 AM
