Tail Lights Removal
Old Apr 11, 2003 | 09:10 AM
raceman3's Avatar
raceman3
Tail Lights Removal
I need to replace the blinker bulb in my rear tail light but I'm not sure how to get the covers off. When I open the gate there are two tork screws on the top of the cover but even after removing them I can't get the cover off. It looks like there are screws in the lower part but there's no way to access them. Any help would be appreciated
Old Apr 11, 2003 | 09:26 AM
Racerguy's Avatar
Racerguy
Tail Lights Removal
The bottom of the light has 2 "pins" that fit into sockets in the body. You just remove the screws at the top and pull the light out.
Sometimes they fit pretty tight.
Old Apr 11, 2003 | 09:32 AM
raceman3's Avatar
raceman3
Tail Lights Removal
Thanks. I thought that might be the case but I was afraid I was going to crack the cover because it's in there pretty tight. I'm assuming you have to pull them straight out so you don't break the pins
