CT November B/s Thread
#156
I have been trying very hard to listen this morning, but simon and garfunkel acoustic is rough.
#158
Iuiopfdtrewqafjhgdtuuuygfryujibncxznkiugfdreewmnb vvccxiiuiiytrreewplmkiuhgfhhvjhhgfdbvnhhjnghbuhheb gt
Lpprbndnvdndbzgjbhhgbhghhgghhhhhrhdhjjhjxbdkhkgjdi ejvjgdqhjjshwhehehfhduehheherjbjkkjjdqjdhdoenbvndf jvwds,h,lpyjoouihwgffgffhhhruuuwwteeyuuuuugfgredcb gytrreewwqjjkfhrkjekjeheehdhbbfvhllpcbsrsgehhheheh efehegwjegehjjeejhehv,djhfqjdkellek nrgsfwgazxbfhegeyeyjkkqjkejejekeoehejerihrgjhcajge wjrhejjehrjjkkjjfjfjjhdirheiriiieujkrjkekrjedcvbiu yytrftwepol,hhfrfhnmnjjbnnnhrkrrhfruhjjqkdeueegmcd jgdkgnbnfjhdjrjhrjjgrrtjjtjjkfkrrkehdiudhvhigrtthd hjfqgbbbvszXdfhhhhtyujrjrkbirhrjfffjjgjmhmjrirdkhd jd
Cond,mdnbdjfxmbnfgtrrooooojrugfgrtasasdfghjklqwert yuiipzzxcvbnm,.,.Jhhdgfqjfhjfhjdfhrmjfhfjbdjdfrbeh jvhfksgdfarrgfghgvhgjgffvc aabbbcaxz hgudgjejeegjdejgeghidtfvgfffdasdfefwfk,,k,lllllllk kyenjewnjjghgiiiiiiijqnjxcdasxcz jk,
#160
I agree completely
#163
Well I didn't wake up intending to be productive today but it just sorta happened.
Went down to the shop and went riding for an hour or so... then decided to rotate my tires. Got done with that and thought hmm I looked up where to find the up-fitter wires on the 06 last night. I should try to find those. Found them. Hooked up the high idle wire to Aux 4. It works just fine.
Drained the HFCM because it was throwing a water in fuel message.Then I loosened the lug nuts on the rear axle of that truck sprayed PB blaster wherever I could. I've probably done 4 miles or so at under 35 with the nuts loose hitting every bump I can safely. Also been trying to take corners pretty quickly to side-load everything in an effort to break the wheels free.
#164
