6.2L V8 Discuss the 6.2L V8
1st Oil Change Pics added
Old 10-31-2011, 04:42 PM
tbar1963's Avatar
tbar1963
tbar1963 is offline
Hello..Did my first oil change on my 2011 Lariat Limited. Did this at 1,994 miles.
I know they say you don't need to do the first oil change so soon, but i'm old school that way.
Read a lot of posts here about how tight the filter was put on from the factory, and also how Ford Engineers should have to do their own oil changes for 5 years.
One post recommended the 3 jaw Craftsman oil filter wrench..47064...I found it to be part #028-20523..
Well I will say that is a nice filter wrench, and I did not find the filter to be over-tight...the engineers even put a plastic drip tray under the side mounted oil filter ( when loosened ) to direct the oil directly into your oil pan...Very Nice...never seen that before..
Used exactly 7Qts to top fill mark...
Over-all...a very easy...and clean oil change...
Just wanted to report on my experience...Thanks...Tom
Old 10-31-2011, 05:14 PM
Mike in PA's Avatar
Mike in PA
Mike in PA is offline
We need a picture or three of that drip
tray tbar. Don't have one on my 2011. Seen them on
the Asian cars though...
Good luck with the new 2011.
Mike in PA
Old 10-31-2011, 05:15 PM
rkmfordman's Avatar
rkmfordman
rkmfordman is offline
mine went easy on my 2011 superduty too my sons 2008 2.3l ranger was the worst one i ever seen the filter was in pieces when we got it off i dont know how they cud get it that tight!!!
Old 10-31-2011, 07:46 PM
tbar1963's Avatar
tbar1963
tbar1963 is offline
Mike in PA
Hey Mike....I'll work on that for you....
Tom
Old 10-31-2011, 08:08 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
I don't have one of those drip trays either. Had one on my Jeep and it was nice, you know where to put the pan and keeps everything very clean.
Old 11-01-2011, 09:21 PM
socapots's Avatar
socapots
socapots is offline
thats cool stuff man.
And like the others said.. lol. pics of the drip tray thinggy.
Old 11-02-2011, 11:02 PM
tbar1963's Avatar
tbar1963
tbar1963 is offline
Hi guys...took some pics as requested...kind of difficult pictures
to take..hope you can make heads or tails of these...this is of
the drip tray factory installed on my 2011 Lariat Limited 6.2L
the first and last picture are the most clear...the two in the middle got turned 90*
making them harder to look at and put in perspective...
Thanks...Tom
Old 11-03-2011, 08:04 AM
socapots's Avatar
socapots
socapots is offline
Good pics man.
Did my first oil change as well but didnt notice that at all. lol. Next time i'll have to take a better look.
Old 11-03-2011, 06:06 PM
Mike in PA's Avatar
Mike in PA
Thanks for the photos tbar. Guess things under the
motor changed some. My filter hangs straight down
and when changing, oil pours out every which way when the
filter is removed. No drip tray either.
Enjoy the new rig sir...
Mike in PA
Old 11-03-2011, 07:29 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Mike in PA
Mine is straight up and down too. I just use the filter punch trick to drain the oil from the filter first the take it off without a mess.
Old 11-03-2011, 09:43 PM
socapots's Avatar
socapots
socapots is offline
Mike in PA
hmm.. come to think of it.. I think mine is vertical as well.. Now i wanna go outside and check. lol.
Old 11-04-2011, 06:09 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
I think the OP has a F-150, may be a different setup under the truck than the SD's
Old 11-04-2011, 01:47 PM
tbar1963's Avatar
tbar1963
tbar1963 is offline
You are correct sir..2011 Lariat Limited F150..understand the confusion
now..6.2L only offered in F150's...Lariat, Raptor, Harley...
Most people here F250 or larger....
Love the growl, power of the 6.2L Beast...Tom
Old 11-04-2011, 03:23 PM
handyman43358's Avatar
handyman43358
handyman43358 is offline
Holy cow, Ford is still using the FL-820S filter. Got that one on my '95 351. You know what they say, if it ain't broke...
Old 11-04-2011, 07:20 PM
Mike in PA's Avatar
Mike in PA
Just punch a hole into the filter and let drain before removal?
Mike in PA
Quick Reply: 1st Oil Change Pics added
