fuel pump problems
Old Nov 13, 2002 | 12:40 PM
highroller95's Avatar
highroller95
Post fuel pump problems
hey everyone iv'e got a 95 f150 4x4 and my feul pump wont work ive checked all the fuses relays and inertisa swicth replaced the pump and still nothing any ideas!!!! all help greatly appreciated..................
Old Nov 13, 2002 | 05:53 PM
Mil1ion's Avatar
Mil1ion
fuel pump problems
Old Nov 13, 2002 | 07:08 PM
edenroadmaster's Avatar
edenroadmaster
fuel pump problems
first, check the maxifuses under the hood. should be on the drivers inner fender. if they check out, start at the fuse block and check the wires with a multi meter. check all the various points in the circut until you either find the short or hit the fuel pump. if everything is ok to the fuel pump, then the pump is bad.
Eden
Old Nov 13, 2002 | 07:09 PM
samhihn's Avatar
samhihn
fuel pump problems
If it was me I'd start checking for voltage at different places in the system. If you've got voltage at the relay, then follow it on down to the pump checking as you go. If you don't have power at the relay , follow it on back the other way.
Old Nov 13, 2002 | 10:09 PM
steve83's Avatar
steve83
fuel pump problems
Yep - I'd start at the pump, too, and work backward. That is, AFTER checking the fuses, of course.
