Help! 1994 4.0L Ranger misfiring & hesitating under load?
Old 04-28-2017, 03:07 PM
jdhford67's Avatar
jdhford67
jdhford67 is offline
Exclamation
So i know this is an ancient thread at this point, but I have the exact same truck and issues, was there ever a remedy?? I've dumped more money in the truck than it is worth to figure it out and still nothing. ANY help would be GREATLY appreciated!
Thank you!!
Jake
Old 04-29-2017, 03:54 PM
dave2271's Avatar
dave2271
dave2271 is offline
I believe there were several solutions depending on how your specific trouble shooting resulted. Mine is a combination of bad gas and clogged catalytic convertors, but all that trouble shooting may caused me a burnt exhaust valve also.
Old 12-29-2017, 06:07 PM
pintobobster's Avatar
pintobobster
pintobobster is offline
DAVE2221
Thanks for the follow up
so many times issues are posted but repairs or what was found is never reposted to help others when doing issue research on there own
Old 12-29-2017, 11:33 PM
a rancher's Avatar
a rancher
a rancher is offline
a rancher
I had sameproblem with my2003 ranger 4.0 4x4, 5speed at100,00plus miles.
took to dealer, plugs, wires, coil pack still missed going up a hill, took it to
a real mechanic, hooked to his lap top.took it for a test drive, gone 5minutes, said #3 plug was miss firing, changed to another new plug and wire, ran like did when bran new. ran it hard through the gears, no more
miss fire, ford dealer really hosed me an never fixed it. good luck.
Old 01-02-2018, 11:32 AM
pintobobster
MIS-FIRE ISSUE IN CYLINDER #3 FIXED
So found and fixed my mis-fire issue in number #3 cylinder.
pulled spark plug and the white ceramic half was missing, replaced spark plug and back to running normal.
WHEW!!!
could have been worse.
Old 02-20-2018, 10:51 AM
inkfrek1's Avatar
inkfrek1
inkfrek1 is offline
help 1994 ford ranger 4.0L v6 4x4 automatic studering and hesitationg
The truck dose the same as yours but it shuts off when you give it the flue to go up a hill and let off the gas it stalls and when its warm it goes away and studers and hesitates when idles and dose the same when slow acceleration and high way acceleration
Old 03-01-2018, 05:41 PM
pintobobster
OH NO.....
have you tried pulling your codes yet??
if you have not change plugs and wires (mini tune-up) check fuel pressure, change fuel filter, I would do the little inexpensive stuff that probably should be changed.
but I would read the codes first IF any
Old 05-28-2018, 12:53 AM
pintobobster
GOTTA LOVE IT
Another issue non follow up if repaired??
fixed??
or tossed to the bone yard
INKFREK1
and you asked for help....
Stumped13
1983 - 2012 Ranger & B-Series
11-06-2018 08:44 AM
diverdarryl
10-05-2018 08:08 AM
chris110587
18
03-18-2017 12:24 PM
mhofmann86
09-22-2015 03:45 AM
jimjoebob99
1999 to 2016 Super Duty
11-14-2011 07:30 AM
Quick Reply: Help! 1994 4.0L Ranger misfiring & hesitating under load?
