Help! 1994 4.0L Ranger misfiring & hesitating under load?
a rancher
I had sameproblem with my2003 ranger 4.0 4x4, 5speed at100,00plus miles.
took to dealer, plugs, wires, coil pack still missed going up a hill, took it to
a real mechanic, hooked to his lap top.took it for a test drive, gone 5minutes, said #3 plug was miss firing, changed to another new plug and wire, ran like did when bran new. ran it hard through the gears, no more
miss fire, ford dealer really hosed me an never fixed it. good luck.
help 1994 ford ranger 4.0L v6 4x4 automatic studering and hesitationg
The truck dose the same as yours but it shuts off when you give it the flue to go up a hill and let off the gas it stalls and when its warm it goes away and studers and hesitates when idles and dose the same when slow acceleration and high way acceleration
OH NO.....
have you tried pulling your codes yet??
if you have not change plugs and wires (mini tune-up) check fuel pressure, change fuel filter, I would do the little inexpensive stuff that probably should be changed.
but I would read the codes first IF any
Stumped13
1983 - 2012 Ranger & B-Series
11-06-2018 08:44 AM
chris110587
18
03-18-2017 12:24 PM
mhofmann86
09-22-2015 03:45 AM
