Car Problems. Need Help
Old Oct 30, 2011 | 09:24 AM
79shortbed's Avatar
79shortbed
Hi Folks,
I have a carburetor issue. It’s a 2100 and was rebuilt about a month ago. I’ve been dealing with this issue ever since then. I’m just getting time to work on it. Here are the symptoms.
1. Truck starts up fine in the morning. Electric choke good.
2. I drive the truck around for about a 1/2 hour. Turn the truck off and try to restart. No problem.
4. I Let it set for more then a ½ hr and it will not start without pumping the gas 4 to 5 times.
5. Lots of gas fumes, probably due to the excessive gas pumping.
6. No problems driving it around.
Thanks,
Old Oct 30, 2011 | 09:30 AM
elgemcdlf's Avatar
elgemcdlf
Sounds like the float has a hole in it. Fills and then when you shut it down it sinks enough to hold the needle open draining the bowl. If not that still sounds like the needle is open when it should be closed.
Old Oct 30, 2011 | 09:51 AM
fmc400's Avatar
fmc400
MSEE
Next time you try step 4, instead of pumping the gas 4 to 5 times (which will flood out the carburetor and mask the issue you're trying to solve), gently hold the gas pedal down about 1/3 of the way, then crank the motor over with the pedal held there. If it fires, let off the gas. Does this procedure work instead?
Old Oct 30, 2011 | 11:39 AM
79shortbed's Avatar
79shortbed
Thanks for the replies.
Had the float replaced at the time of rebuild. I verified the 7/16 setup yesterday. It was a little off. No change.
I tried step 4 with 1/3 pressing peddle. Started in 10 to 15 sec. A little long. My 78 starts in less then 3 sec.
Old Oct 30, 2011 | 11:52 AM
elgemcdlf's Avatar
elgemcdlf
Regardless of having the float replaced it may still have a pinhole in it. Possibly dirt holding the needle open.
Old Oct 30, 2011 | 08:21 PM
79shortbed's Avatar
79shortbed
Ok. Installed a new floater and needle. No change What ells could be going on?
Old Oct 30, 2011 | 08:50 PM
elgemcdlf's Avatar
elgemcdlf
Check to verify the throttle plate is closed when the truck is hot and off. When the truck is hot what is the idle RPM? Automatic or manual trans?
Old Oct 30, 2011 | 10:22 PM
fmc400's Avatar
fmc400
MSEE
It's possible that fuel is seeping past the threads of the power valve, or a hair-line crack in the fuel bowl is letting fuel seep into the intake manifold once it's warm. Since it started after the rebuild, the former is the more likely of the two.
Old Oct 31, 2011 | 06:32 AM
elgemcdlf's Avatar
elgemcdlf
Hadn't thought about that. In any case it sounds like the bowl is running dry or at least very low.
Old Oct 31, 2011 | 02:08 PM
79shortbed's Avatar
79shortbed
Elgemcdlf
I'll check the throttle plate when the truck is hot and off. I don't know how to check the RPMs and its an automatic.
fmc400
I did notice some fuel in the intake after removing the carb. Something is allowing the fuel to leak by. I read on how to check the float with carb on/gas. I've been checking the float with a dry chamber. I'm going to verify the power valvue.
I'll get back to you guys by end of week with results. Thanks again for the help.
danger-dave
Bronco II
Sep 26, 2017 11:25 AM
Eddillard79
20
May 4, 2014 02:33 PM
pete315
Dec 31, 2009 06:54 PM
Creedog
Nov 15, 2008 06:07 PM
Pompanosix
General Automotive Discussion
22
Jan 10, 2006 05:57 AM
