Sponsored by: Real Truck
Wheel offset question
Old Oct 29, 2011 | 03:56 PM
Quad Racer's Avatar
Quad Racer
Alright I've been searching the web and this site trying to find my answer so bare with me if I have missed something.
What I want to do is get a new set of wheels and tires. It has always bugged me that these trucks look so narrow at the bottom. I'm wanting to get wheels with a negative offset to get them out of the truck a little.
The setup I like is the XD addict wheels 18x9 with a -12 offset. On those I'd like a slightly taller tire. I'm hoping a 295 70 18 Nitto trail grappler. The tires are 34" tall and 12" wide.
With the wheels out of the truck further, would I have trouble fitting without rubbing on the fender or bumper? I understand you can fit 35's on this truck but just not sure with the offset/wider tire. Anyone with a negative offset setup or tire/wheel expertise please soundoff. BTW I have a completely stock truck and dont want to lift it cause I use it. Just want a slightly more aggressive look. Thanks ahead of time.
Old Oct 29, 2011 | 08:13 PM
Will Bite's Avatar
Will Bite
I have a 06 and running moto metal 950 with a -21 with toyo m/t 33x12.50/18 and they stick out about a inch and a half or two.
Old Oct 30, 2011 | 12:03 AM
Quad Racer's Avatar
Quad Racer
Thanks for your reply! So I will assume you have no lift and no rubbing problems? It sounds like your look is similar to what I'm going for.
Old Oct 30, 2011 | 04:04 AM
Will Bite's Avatar
Will Bite
No lift no rubbing all stock.
Old Oct 30, 2011 | 07:48 AM
Quad Racer's Avatar
Quad Racer
Thanks will bite, I dont want to F this purchase up.
Old Oct 30, 2011 | 10:14 AM
Will Bite's Avatar
Will Bite
It could be expensive if you f up that. Check out my pictures. I had about $ 2100.00 in wheels & tires.
Old Oct 30, 2011 | 12:26 PM
Quad Racer's Avatar
Quad Racer
Yeah I dont want to go too small and hate the tires for 2 years. And I dont want to get a tire too big that will require a lift right away. I believe the set up I'm looking at will fit no problem. It always helps to have reassurance when $2k+ is involved. I found a guy on ebay that is operating out of cincy, so I'm working with him on getting them so I can just pick them up and support local business. I think I'm gettting a decent deal at just over $2k out the door.
Old Oct 30, 2011 | 02:06 PM
Will Bite's Avatar
Will Bite
Good luck to you and don't forget pictures when your done!
Old Oct 30, 2011 | 07:37 PM
Quad Racer's Avatar
Quad Racer
Well I have seen every truck on the internet and have decided that what I'm planning will work so I'm ordering them tomorrow morning. I hope to have them bolted up before next weekend so, we'll see. Thanks again for your follow up will bite great name BTW. Will post pics when install is complete.
gravedgr
Aug 14, 2018 11:31 PM
myakkacracka
Jun 16, 2016 09:39 AM
eduhat
Apr 20, 2016 12:13 PM
Night Bird
Aug 21, 2009 05:58 PM
