Offroad & 4x4
Re-gearing front
Old Apr 10, 2003 | 07:31 PM
sandrat's Avatar
sandrat
Re-gearing front
I have a whole new rear axle (3.50, limited slip) lined up to replace what I have now (3.08, open) in my 91 F-150. Since it's 4wd, I obviously need to re-gear my front end too, if I want to run 4x4. How hard is it to re-gear a TTB front end, or should I let a shop handle this? Thanks
Old Apr 10, 2003 | 08:24 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Re-gearing front
Regearing a TTB isn't much more trouble that regearing a straight axle. If you have the tools and knowledge and have ever regeared anything, I'd say go for it. If you don't have the tools or don't know what tools you need then I'd say take it to a shop. Diff set up can be tricky. Not always, but sometimes you'll find a diff that will be a real bear to set up for one reason or another.
Old Apr 10, 2003 | 08:40 PM
tellico racing's Avatar
tellico racing
Re-gearing front
I did mine myself....But I bit off more than I could chew, I got it set up correctly but it took a while. I would say take it to a shop, The bearings have to be pressed on and off the carrier as you add or remove shims.I ended up increasing the I.D. of a set of bearings so they would slip on and off and used them as a mock up.
Old Apr 11, 2003 | 01:42 AM
pbrstreetg's Avatar
pbrstreetg
Re-gearing front
Yeah you might want to shop that around unless your deadset on doing more of the same work in the future. The first thing you're gonna learn is you need a case spreader to remove the carrier.
Old Apr 11, 2003 | 05:37 AM
tellico racing
Re-gearing front
It can be done without a case spreader, but that would have made things much easier when I did mine.
Old Apr 11, 2003 | 11:06 PM
RCrawler's Avatar
RCrawler
Re-gearing front
The shop that I work for builds about 400 differentials a year. We don't even have a case spreader in the shop. I use a prybar and a wrench on one of the ring gear bolts to remove, and a brass hammer to install the Dana carriers. It is very simple to do. I can tell right away when the carrier bearing preload is right by how the carrier goes into the housing.
You have to be very careful when using one. You can easily break or bend the housing if you go too far. This is why it is crucial to use a dial indicator with the case spreader.
Jason
Old Apr 12, 2003 | 12:30 AM
Ryan50hrl's Avatar
Ryan50hrl
Re-gearing front
I'd second that...you don't really need a case spreader...i've done it without it a couple times.
Old Apr 14, 2003 | 03:27 PM
John Barleycorn's Avatar
John Barleycorn
Re-gearing front
I think the 3.50 is probably the most common gearset for full size Fords. You could pick a complete center section up at a salvage yard and swap yours out in a few hours.
That would probaby be a lot cheaper if you are having someone else do the gear swap for you.
Just a thought.
Louislindsey72
Aug 18, 2017 04:12 AM
az4x4bronc
Aug 22, 2016 02:07 PM
peeples93
1978 - 1996 Big Bronco
Sep 11, 2015 10:09 AM
aarmao
2009 - 2014 F150
13
Jun 11, 2011 06:50 AM
MatthewC
Sep 5, 2004 02:57 PM
