Project 1977 F-250 4x4 Build
#31
It's been a while since I've updated this thread. I seem to be terrible at snapping pics, both before and after. I've spent the last few months degreasing, rebuilding, priming, and painting all kinds of things. I started with the transmission. I cleaned it up and added new seals and gaskets throughout. Next up was the front Dana 44. I had to put new gears in it, new seals, u-joints in the axles, and even had to replace the outer shaft of the LH axle. Not cheap
The power steering pump was a learning experience. Imagine my surprise when I pulled the pump apart and the slippers and springs went everywhere! It actually wasn't that bad when I found good instructions online. The manual with the rebuild kit was terrible.
I also cleaned up the intake real nice. The motor is basically built now. I spent the weekend painting and resealing the transfer case. Here are a few pics:
#34
#36
I haven't been the greatest with remembering to grab my camera as I progress, but here are some updates:
I'm rebuilding my steering gear box. I'm having trouble finding the needle bearings inside. I called Stear and Gear in Columbus, OH (semi-local to me), and they wouldn't sell parts but gave me helpful information. Apparently there WERE needle bearings originally in this gear box, but they are not caged. There is an upgrade to this bearing, and I need to find a Torrington 2012. The problem is there is a b, j, hk...etc all prefixes of the 2012. Some research is necessary.
#37
This past weekend I pressed the studs out of my hub assembly and got new rotors. Pressing the studs back in was a chore, as well as pressing the new inner bearing races into the hub. It kept going in on an angle and jumping out on one side at me.
I just finished powder coating my valve covers in black wrinkle tonight. They're not perfect, but they weren't the best to start with. I'll probably upgrade in the future.
I also welded my new u-joint on the end of the steering shaft. My old one was so bad that I could turn the steering wheel almost 90* and still go straight. I can't wait to see the difference this makes!
Now I'm working on my hack job of a wiring harness
More to come...
More to come...
#42
#43
#44
