Fuel Heating Element
Old Oct 26, 2011 | 03:59 PM
MauleOne's Avatar
MauleOne
I had a fuse blow on my E99 F350 PSD that turned out to be #30 and a 30 amp unit. It disabled my truck.
I unplugged the fuel bowl heater and replaced the fuse. Truck ran fine.
Now, while rebuilding my fuel bowl I see that the heating element in the bowl has come adrift. So I removed it from within the bowl and not having a replacement on hand left it out. It is still unplugged on the outside.
Now I read that this is also my water-in-fuel element.
Does leaving the external plug undone mean I no longer have water-in-fuel sensing?
The question is, should I buy a new heating element and reinstall it, or can I just forget the whole thing.
I see that Riffraff has heating element for sale ane I am about to order some other parts from them.
Old Oct 26, 2011 | 04:07 PM
PaysonPSD's Avatar
PaysonPSD
Just plug the connector back if for the WIF sensor to work.
Replace the element if you want, but it really isn't going to do you any good even at the North Pole.
Anti-gel additive will work for the whole fuel system. The heater only works for the fuel in the bowl and only after the key is on.
Old Oct 26, 2011 | 04:12 PM
MauleOne's Avatar
MauleOne
Heater
Thanks for the response
Old Oct 26, 2011 | 07:17 PM
Kwikkordead's Avatar
Kwikkordead
I took my fuel heater out last year.
No plans to ever put it back.
Old Oct 26, 2011 | 07:55 PM
riverrat41's Avatar
riverrat41
Me as well...^^^^ What they said.
Teamrope
Nov 25, 2015 07:14 AM
tshrager
Dec 28, 2011 03:06 PM
onelionhunter
Mar 8, 2011 01:18 AM
97F350 7.3L ID
21
Oct 30, 2008 01:20 AM
firemanp
Dec 4, 2006 03:06 PM
