a/c question
Old Oct 25, 2011 | 05:42 PM
bigbubba87's Avatar
bigbubba87
a/c question
I just bought a 99 f350 I can't get any cold air out the vents. Compressor operates fine. Everything else works but no a/c. What shuts off coolant flow to the cab when a/c is on. What does the temperature control change to make it hot or cold.
Old Oct 25, 2011 | 05:45 PM
timmyboy76's Avatar
timmyboy76
check this out...
SpringerPop's Compressor Clutch Air Gap
Old Oct 25, 2011 | 11:10 PM
bigbubba87's Avatar
bigbubba87
I did. And its not the problem. Everything works like it should pressures are good. But I can't get any cold air out the vents.
Old Oct 25, 2011 | 11:12 PM
BigAlsPSD's Avatar
BigAlsPSD
Is your blend door actuating?
Old Oct 26, 2011 | 07:24 AM
nlemerise's Avatar
nlemerise
Nothing shuts the coolant off when you turn on the ac...you can mod with a vacuum valve or a simple shutoff valve in either of the heater hoses coming to the firewall. When the key is turned on, before actually starting, do you hear the vacuum pump running?
Old Oct 26, 2011 | 08:54 AM
bigbubba87's Avatar
bigbubba87
Yes the blend door is acuating I mean floor vent and defrost work fine. I'm pretty sure the vacuum pump is working.
Old Oct 26, 2011 | 09:01 AM
bigbubba87's Avatar
bigbubba87
Where is the blend door acuator
Old Oct 26, 2011 | 01:24 PM
BigAlsPSD's Avatar
BigAlsPSD
Should be located behind the glovebox, on top of the ductwork. It has an electric motor that moves a door about 90 degrees, not near the problems with these trucks as there were with earlier fords, but its a possibility.
Old Oct 26, 2011 | 02:08 PM
PaysonPSD's Avatar
PaysonPSD
This is for the manual HVAC system. I don't have it for the Auto Climate system. This plus a vacuum gauge are good trouble shooting tools.
Have you actually hooked up gauges to be sure the compressor is actually working and the r134 charge is good?
Old Oct 26, 2011 | 11:04 PM
bigbubba87's Avatar
bigbubba87
Yes I hooked gauges up and pressures were fine. The high side pine is hot and low side sweats.
Old Oct 26, 2011 | 11:19 PM
bigbubba87's Avatar
bigbubba87
Should the vacuum pump run for a few seconds every Time the key is turned on?
Old Oct 26, 2011 | 11:26 PM
BigAlsPSD's Avatar
BigAlsPSD
It is on a vacuum switch, so if the switch is not made it will not come on, did you ever look to see if your blend door motor is turning on when you change temperature?
Old Oct 27, 2011 | 01:43 AM
twags6's Avatar
twags6
It won't run every time, only when the vacuum is low. Its setup like an air compressor, on at a low vacuum and off at a higher vacuum. The fact that you can get the air to blow out of the floor and dash means you have vacuum. When you don't, the air will only come out the defrost vents.
Old Oct 27, 2011 | 01:44 AM
twags6's Avatar
twags6
double post
Old Oct 27, 2011 | 02:39 PM
PaysonPSD's Avatar
PaysonPSD
Here's a wiring and component diagram for blend door electrics.
