I have a 96 xlt. my brother has a 69. What i am wanting to know is will the insignia that is on his bronco(the cursive script) on the front fenders match up with the hole paterns on my front fenders on my 96. For some reason i like the way his insignia looks better than what is on mine. Just a little idea for some personal customizing.
They don't. Checked into this with my brother's 76 and my 92. Won't stop me though. Drill new holes and fill up the old ones. But then I want the 302 emblem too.
I wouldn't want to drill holes in my truck if I didn't have to. I would just cut the pins of of the emblems an sand it smooth, then just apply the adhesive. I would like to get the 351 emblem, I think that would look really hot! where would you put it tho? unber the factory Bronco emblem or what?
Does anyone know if the emblems from Bronco Graveyard come with adhesive on them already? It would be hard to put adhesive on the BRONCO emblem while getting the holes in the B, O, and C.
Yup, I ordered a couple of the Eddie Bauer emblems from BG, and they come with the adhesive already on. Had a little problem with one of them, but got it worked out and they look great.
No, those emblems do not come with double sided tape. I put them on my 96 bronco and what you have to do is pre-drill some holes, then install these little clips into the holes and they in-turn hold the emblem on.
SmaulzEB, I am wondering where you ordered those "Eddie Bauer" emblems from. I need to replace mine because that clear peice on both sides peeled off so it doesn't say "Eddie Bauer" anymore
SmaulzEB, I am wondering where you ordered those "Eddie Bauer" emblems from. I need to replace mine because that clear peice on both sides peeled off so it doesn't say "Eddie Bauer" anymore [/B]
That's exactly what mine did. They weren't that expensive. The only problem I had was one was already peeling back when I received it... GRRR... but a little 2-part epoxy fixed that problem.
{EDIT}
wow... just checked the page again, the price has gone up... they're $19 bucks each now.. I think I paid just under $12 each shipped. I guess you'll have to decide if they're worth it or not.
I think that I'm going have to buy the emblems. Are there any holes in the front quarters for the eddie bauer emblems or is that just the the bronco one? Do you know where I could find the stainless steel piece that goes on the tailgate? I don't know where to look and could I ever put the tire rack back on my truck? because the guy that replaced the quarter panel didn't put the brackets on the inside or outside...(theres no rack anymore) and it looks to plain and boring with out it. does anyone have any Ideas on what I can do with it? check my gallery for the rear view side of my truck)
any ideas would be great!
I don't have a rear tire carrier on my Bronco and I think it looks better without. Mine has the rear vanity plate on the tailgate and I think that helps a lot. I like being able to actually see out the rear window.
Amen on the Tire Carrier greystreak92, I don't want to give up any room inside my Bronco, plus..wadda ya talking about can't see out the rear window? I can see just fine out mine!
